IBNS 2.0 missing "dot1x timeout tx-period" after switch reload
Bob Goal
Hi Community,
I'm preparing config for 802.1x deployment and encountered a problem. I'm using IBNS 2.0 syntax like below and try to make "dot1x timeout tx-period" lower, from 30 to 10 seconds. Unfortunately after switch reload, command "dot1x timeout tx-period" is missing in running-config but is present in the startup-config. Because of that switch send EAPOL frame every 30 sec which is to long for me. Is there any way to accomplish my goal with IBNS 2.0?
Switch 2960X with IOS 15.2(2)E6:
Before reload:
running-config:
interface GigabitEthernet1/0/1
switchport access vlan 110
dot1x timeout tx-period 10
source template ISE
startup-config:
source template ISE
After reload:
running-config:
dot1x timeout tx-period 10   <- command is missing
source template ISE
startup-config:
source template ISE
Config:
dot1x system-auth-control
dot1x logging verbose
dot1x critical eapol
service-template DEFAULT_CRITICAL_VOICE_TEMPLATE
voice vlan
service-template CRITICAL
access-group ACL_CRITICAL
voice vlan
service-template CRITICAL_ACCESS
service-template CRITICAL_VOICE
voice vlan
class-map type control subscriber match-all AAA_DOWN
match result-type aaa-timeout
class-map type control subscriber match-all AAA_SVR_DOWN_AUTHD_HOST
match authorization-status authorized
class-map type control subscriber match-all AAA_SVR_DOWN_UNAUTHD_HOST
match authorization-status unauthorized
class-map type control subscriber match-all DOT1X_FAILED
match method dot1x
match result-type method dot1x authoritative
class-map type control subscriber match-all DOT1X_NO_RESP
match method dot1x
match result-type method dot1x agent-not-found
class-map type control subscriber match-any IN_CRITICAL_AUTH
match activated-service-template CRITICAL_ACCESS
match activated-service-template CRITICAL_VOICE
class-map type control subscriber match-all MAB_FAILED
match method mab
match result-type method mab authoritative
class-map type control subscriber match-none NOT_IN_CRITICAL_AUTH
policy-map type control subscriber POLICY_DOT1X_MAB5
event session-started match-all
  10 class always do-until-failure
   10 authenticate using dot1x priority 10
   20 authenticate using mab priority 20
event authentication-failure match-first
  5 class DOT1X_FAILED do-until-failure
   10 terminate dot1x
  10 class AAA_SVR_DOWN_UNAUTHD_HOST do-until-failure
   10 activate service-template CRITICAL_ACCESS
   20 activate service-template CRITICAL_VOICE
   50 authorize
   60 pause reauthentication
  20 class AAA_SVR_DOWN_AUTHD_HOST do-until-failure
   10 pause reauthentication
   20 authorize
  30 class DOT1X_NO_RESP do-until-failure
   10 terminate dot1x
  40 class MAB_FAILED do-until-failure
   10 terminate mab
   20 authentication-restart 60
  50 class always do-until-failure
   10 terminate dot1x
   20 terminate mab
   30 authentication-restart 60
event agent-found match-all
   10 terminate mab
   20 authenticate using dot1x priority 10
event aaa-available match-all
  20 class NOT_IN_CRITICAL_AUTH do-until-failure
   10 resume reauthentication
template ISE
dot1x pae authenticator
spanning-tree portfast
spanning-tree bpduguard enable
switchport mode access
source template IP_PHONE_INTERFACE_TEMPLATE
mab
access-session closed
access-session port-control auto
authentication periodic
authentication timer reauthenticate server
service-policy type control subscriber POLICY_DOT1X_MAB5
source template ISE
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server dead-criteria time 10 tries 3
radius-server deadtime 15
radius server RADIUS_ISE02
address ipv4 IP_1 auth-port 1645 acct-port 1646
automate-tester username RADIUS-TEST probe-on
key 7 ***
radius server RADIUS_ISE01
address ipv4 IP_2 auth-port 1645 acct-port 1646
key 7 ***
6 Replies 6
Craig Hyps
Level 10
Level 10
Try adding the command to your source template ISE.
Hi chyps,
thank you for the quick response. Unfortunately there is no such command under template
c2960x(config)#template ISE
c2960x(config-template)#dot
c2960x(config-template)#dot1x ?
  pae  Set 802.1x interface pae type
hslai
This appears an issue either specific to IBNS 2.0 and 15.2(2)E6 on 2960X. So, I am moving your question to Switching
Bob Goal
Team,
is the command dot1x timeout tx-period deprecated now? Is there any plan to implement it with interface template feature? Or maybe there is other, better way to send dot1x frames from Catalyst switch in shorter interval?
I don;t know if i am right or not so i hope one of the experts can reply.
Do we still need the dot1x timeout tx period  cmd when using IBNS 2.0 ?
As far as i know from reading the docs that one of the benefits of IBNS 2.0 is the concurrent flexauth which means that when the session is started  both Dot1x and MAB are trying in Parallel with Priority to Dot1x no no need anymore for the fallback sequence.
I hope someone will clarify this.
btw i tried this command on my c2960L switch and i can see it in the cli
Janne K.
I know this is a very old post, but i recently ran into the same problem with my 2960X switches.
I think maybe the problem is the order in which the config is loaded into the interface.
When testing on a default interface i am not able to post the "dot1x timeout tx-period 10" or any dot1x command before i have enabled my "source template DOT1X-port"
My workaround for this 'little problem' is to use the EEM (Embedded Event Manager) to paste the startup-config back into the running-config just after restart of the switch.
It may be a bit crude, but it works, and a wise man once told me: "If it's stupid but it works, it's not stupid."
Anyway, here is the command set i use to make it work on my setup.
The username is a must since we use tacacs to authorize commands.
event manager session cli username "prime-admin"
event manager applet PUSH_START_RUN
event syslog pattern "SYS-5-RESTART"
action 2.0 cli command "enable"
action 2.1 cli command "copy start run" pattern "running-config"
action 2.2 cli command "running-config"
action 2.3 cli command "wr me"
I hope it may help someone in the same situation.
Janne K.
