ICMP redirects
John Blakley
All,
I'm revisiting a redirect problem that I had in the past and I'm starting to disable across all interfaces in our environment. I have a question though. Redirects were originally disabled in earlier versions of the IOS if HSRP was configured on that interface, but as of 12.1 (I know, still old) it enables redirects by default.
Usage Guidelines
Previously, if the Hot Standby Router Protocol (HSRP) was configured on  an interface, ICMP redirect messages were disabled by default for the  interface. With Cisco IOS Release 12.1(3)T, ICMP redirect messages are  enabled by default if HSRP is configured."
I've disabled redirects on my hsrp interfaces, but I'm wondering what type of an impact this is going to have should I need to failover? I know it shouldn't have "anything" to do with it, but my concern is that Cisco chose to enable by default for some reason. Does anyone know why?
John
HTH, John *** Please rate all useful posts ***
Jon Marshall
j.blakley wrote:
All,
Usage Guidelines
John
John
It won't affect failover between the routers using the same HSRP group because the end devices only see the VIP and virtual mac and so they will fail over correctly.
As for why it iwas disabled, bit isn't now have a read of the overview in this doc which explains it better than i can ! -
HSRP ICMP redirects
Jon
5 Replies 5
Jon Marshall
j.blakley wrote:
All,
Usage Guidelines
John
John
HSRP ICMP redirects
Jon
As always Jon, you're awesome! Thanks!
Peter Paluch
Hi John,
The IOS support for ICMP Redirects on HSRP-enabled interfaces has been significantly improved (and obfuscated as well, as could be expected ) which is the reason why the ICMP Redirect feature is enabled on HSRP-enabled interfaces.
You may want to read the following article:
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_hsrp_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1093370
It discusses the rationale behind the ICMP Redirects with HSRP and also the special handling of ICMP Redirect messages. I suggest reading this document first to see how the redirects are handled. Not exactly an easy reading, though.
Best regards,
Peter
Oops,
Sorry guys - I appear to be only repeating what Jon has already answered. I seem to have been late at hitting my "Post answer" button Anyway - Jon, great answer as always!
Best regards,
Peter
Thanks Peter!
