ICND2 - Assign VLAN to Interface
cawinn
Hi All,
I'm adding a Voice VLAN to an interface with an existing data VLAN called Sales.
Do you know why the Voice VLAN doesn't appear with port Fa0/1 ?
Switch1(config)#interface Fa0/1
Switch1(config-if)#switchport voice vlan 3
Switch1(cofi-if)#exit
Switch1(config)#do show vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/21, Fa0/22, Fa0/23, Fa0/24
2    Sales                            active    Fa0/1
3    Voice                            active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
Switch1(config)#
Reza Sharifi
Can you post the output of "sh run int fa01"?
Martin L
sh run int Fa0/1 , copy to notepad, add switchport voice vlan 3,
copy the whole config back to switch port.
if that does not work; default int fa0/1, shut interface, add the whole config back to interface, no shut.
is this a real switch ? if so , what is the model /ios?
the port should show up in both VLANs. What platform is this on, and what IOS ?
interface FastEthernet0/1
switchport mode access
switchport access vlan 2
