Identify devices on network
safiullah647
Community Member
I have task to complete. Is there a way to identify all devices that are connected in to multi tier network. So for example we have a main gateway router which is connected to a switch that switch is connected to 2 other switches and so on. In this multi tier topology if i have to identify how many end devices are connected, via wifi, ethernet, and in VLANs, how can 1 do that. Will we have to identify the end devices by running ip int brief on each network device separately. Or there is a way we can do that in simple way
Will that hard without ISE or any other mgmt Software
But easy way is use show ip dhcp binding
This give you HW and/or it Mac in this way you can know that this printer and that laptop
Other way is cdp
MHM
Other way is cdp
MHM
Which management software can be used in this scenario?
