igmp join group
CSCO10685316
Community Member
I have a WS-C3560G-48TS-S with IOS version 12.2(25)SEE.It will not take the command "igmp join group" when using multicast routing.Please tell me what may be the solution to enable multicast routing on that devices.the matter is very urgent.
ketimun123
Community Member
In 12.2(25)SEE, all feature-set should support this command.
Do you want to use this command ?
ip igmp join-group 225.1.1.1
What error-message do you get ?
after interface config mode when I am giving ip igmp it is not showing join-group. After ip igmp i am getting three option
1)filter
2)max-group
3)snooping
Pls response
As of your listed config-options, I assume you try to configure a Layer 2 port.
If you change it to a Layer 3 port the command should work .
If you still have the issue, please attach sh ver and sh run.
