Impact of ACL on C6509 CPU utilization
All,
Can you please help with the following
We plan to implement a large number of ACL on our Distribution switch which is a HSRP pair of 6509C switches running on
sup-bootflash:s72033-psv-mz.122-18.SXD3.bin
WE need to divide the Network in three layers
unsecure layer
Proxy layer
Secure layer
We have approximately 250 vlans on the our distribution switches and plan to implement 15 ACL on different vlans Each ACL can contain upto 30 lines or less.
basic ACL example we will be applying on different vlan
vlan 200
ip access-group test123 in
My question is
Can these ACL on a vlan can have a massive impact on the 6509 CPU ?
Any Response is much appreciated.
sean_evershed
Level 7
Level 7
See below a previous thread on the subject that will help answer your question
https://supportforums.cisco.com/thread/2116020
Don't forget to rate posts that are helpful.
Cheers
Sean
sean_evershed
Level 7
Level 7
Cheers
Sean
