01-20-2020 01:13 PM - edited 01-20-2020 01:30 PM
What will be the impact on the network and switches if we create let say 1100 to 1400 VLANs with PVST+ on Cisco Cat Switches - i.e CPU will be high, not supported or any other STP related issues. What is the best practice.
ZK
01-20-2020 06:15 PM
01-21-2020 12:30 AM
Thanks Francesco.
Could you please send few links so that I can read about more cpu consumption for each instance and limit of instance for few switch platforms.
Thanks.
01-21-2020 05:06 AM
Hello Zahid,
I think not to exist a document that describe CPU consumption and that each model supports.
To verify models supports, verify in the datasheet.
The Cisco troubleshoot documents, mentioned.
A Layer 2 spanning-tree instance runs for every VLAN configured on a Layer 2 switch by the per-VLAN spanning-tree (PVST) feature. The CPU time utilized by spanning tree varies depending upon the number of spanning-tree instances and the number of active interfaces. The more instances and the more active interfaces, the greater the CPU utilization.
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future.
Best regards,
Lucas Freitas
01-21-2020 07:37 PM
