Impact on network operations if smart license evaluation expires.
kashifglobal12
Dear Cummunity,
Hope you all are good. As the title explain you very much about the problem need to know anyone had any situation like this and is there any impact on the network operation as the license expires.
balaji.bandi
its tricky question, base License features works as expected.
License feature should be disable or stop working, But as such personally the device still working as expected after License expiry.
Not sure cisco have any control if the device not contacting smart License server after X days, features to be turned off, i do not see one of the test environment( may be not a great idea for production kit).
BB
Actually, the switch is not registered with any smart account. Built-in
evaluation has turned on.
what model of switch and can you show us example to understand better of your License.
BB
