Implementing VLANs in a Hierarchical Design
Stuart D
I'm fairly new to this, so I apologise if the solution is obvious.
I'm trying to get the two PCs in vlan10(green) to communicate with each other, however I'm not sure how to do this with a third multilayer switch between them. The multilayer switch is on the distribution layer whilst the standard switches are at the access layer. I could get it working with a connection between just the layer 2 switches, but could anyone help me with the multilayer switch between? I've included a screenshot of the topology as well as what I've configured so far below.
Switch 1:
interface Port-channel1
switchport mode trunk
interface FastEthernet0/1
channel-group 1 mode active
interface FastEthernet0/2
interface FastEthernet0/10
switchport access vlan 10
switchport mode access
interface FastEthernet0/11
switchport access vlan 20
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 0001.97c3.a001
ip address 192.168.10.1 255.255.255.0
interface Vlan20
mac-address 0001.97c3.a002
ip address 192.168.20.1 255.255.255.0
Switch 2:
interface Port-channel2
channel-group 2 mode active
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 0007.ecc6.3901
interface Vlan20
mac-address 0007.ecc6.3902
The multilayer switch has no VLAN configuration yet. The only configuration is for the etherchannel links.
Any help would be greatly appreciated
-Stuart
balaji.bandi
There are 2 ways here :
1. On the Multi Layer you need to have VLAN 10 and VLAN 20
2. Multi Layer switch - Connected to Switch 1 and Switch2 configure as Trunk
3. Enable routing  - Ip routing.
4. configure
interface Vlan10
interface Vlan20
5. Switch1 and Switch 2  - remove below config
no interface Vlan10
no interface Vlan20
6. Configured PC VLAN 10 192.168.10.2 with Gateway 192.168.10.1 and test and advise.
7. Configured PC VLAN 20 192.168.20.2 with Gateway 192.168.10.1 and test and advise.
BB
Hello
The easiest solution would be to remove the addressing of both sw1/2 and apply it to only the distribution switch enabling ip routing along and adding their presepective L2 vlans
Keep the tunking and L2 vlans on all switches as it is.
Note: ip routing is only required for communication between vlans it isn’t required for host to host communication within the same vlan
Kind Regards
Paul
balaji.bandi
4. configure
interface Vlan10
interface Vlan20
no interface Vlan10
no interface Vlan20
BB
Here i am putting Intervlan routing through Multilayer switch configuration. Please go through this configuration file. Which i did couple of hour before
Switch#sh run
Building configuration...
Current configuration : 1668 bytes
version 12.2(37)SE1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
ip routing
spanning-tree mode pvst
switchport nonegotiate
interface FastEthernet0/3
switchport access vlan 30
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 00e0.b054.9801
ip address 192.168.0.1 255.255.255.224
interface Vlan20
mac-address 00e0.b054.9802
ip address 192.168.0.33 255.255.255.224
interface Vlan30
mac-address 00e0.b054.9803
ip address 172.16.0.1 255.255.255.0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
