in built csu on router
mahesh18
Level 6
Level 6
i hav erouter which is
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FTX1024A0Z1
2 FastEthernet interfaces
1 Serial interface
1 Channelized T1/PRI port
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
it has in built csu.
when i do sh controller t1
it shows
sh controller t1
T1 0/0/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20060711, FPGA: 13, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (749 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
66 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
66 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 11 Path Code Violations,
7394 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 11 Degraded Mins,
7404 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
what are these stats doe it show csu /dsu stats or T1 stats
thanks
Richard Burts
mahesh
There are some aspects of your question that I do not understand well. What is the difference between csu/dsu stats and T1 stats?
The csu/dsu provides physical support for the T1 and controls functions such as clocking and framing for the data which is carried on the T1. In some sense perhaps the csu/dsu provide the lower level functions and perhaps you consider the T1 to be the packet level functions. In that case the statictics in the show command are csu/dsu stats.
Rick
Rick
Richard Burts
mahesh
Rick
Rick
Hi rick,
thanks for reply
so sh controller T1 always show stats of inbuilt csu/dsu?
