In STP.Port Identifier = ?
chandra_rc16
Level 4
Level 4
Is the port identifier = port priority and MAC address
or
port identifier = port priority and inteface number (Eg: 128.2 here 128 is port priority and 2 is interface numeber such as Fa0/2)
Which is corrrect ? I'm bit confused.
Actually i got this doubt as i was reading the below info on cisco site:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_53_se/configuration/guide/swstp.html
Spanning-Tree Topology and BPDUs
The stable, active spanning-tree topology of a switched network is controlled by these elements:
The  unique bridge ID (switch priority and MAC address) associated with each  VLAN on each switch. In a switch stack, all switches use the same  bridge ID for a given spanning-tree instance.
The spanning-tree path cost to the root switch.
The port identifier (port priority and MAC address) associated with each Layer 2 interface.
Chandu
Regards, Chandu
Peter Paluch
Chandu,
In STP, the Port ID has two parts: configurable priority and a fixed port number (which is not the MAC address). On many switches, the port number is exactly the number after the slash, i.e. Fa0/1 is 128.1, Fa0/24 is 128.24. On some switches having GigE uplinks, Gi0/1 is 128.1, Gi0/2 is 128.2, and Fa0/1 starts with 128.3, Fa0/2 continues with 128.4, etc. The port numbers have no particular meaning except being unique for each port on a switch.
Best regards,
Peter
Peter, so as per your reply. I think cisco mention the third point worngly.
Chandu
Regards, Chandu
