in this topology , bgp neighbor is not done between R1 & R3 & Both Ro
krahulbgp
in this topology , bgp neighbor is not done between R1 & R3 & Both Router are not even configured by static route ,Will R1 be reachable with R3 in this case bgpQ2.PNG
Hello
R1/R3 should be reachable between each other via their connected peerings of R2/R4
Kind Regards
Paul
5 Replies 5
R1 is reachable from R3; since you announce the 1.0.0.0/8 network on R1, R3 receives that route.
Show ip route,
If you see
Router id or any interface ip of other router then other router reachable.
 As R1 and R3 are in different autonomous system ,therefore, they are eBGP routers, they will not form neighborhood unless you enter the command "ebgp-multihop " Of course, they must have recheability and you need to add both as a neighbor.
R1:
R1(cofig)# router bgp 650014
R1(cofig)# router bgp neighbor 1.1.1.1  remote-as 650003
R1(cofig)# router bgp neighbor 1.1.1.1  ebgp-multihop 2
R3:
R3(cofig)# router bgp 650003
R3(cofig)# router bgp neighbor 2.1.1.2 remote-as 650014
R3(cofig)# router bgp neighbor 2.1.1.2 ebgp-multihop 2
Hello
Kind Regards
Paul
If it is than why we need this command which is mentioned in above trail reply ,getting confused on this
