inconsistent address and mask for static routing
jordan-jj
I am trying to  create  static ip  route from R3 to R1
R3 :  30.30.30.2 /24
R2;30.30.30.1/24  and 10.10.10.2/8
R1:10.10.10.1 /8
R3:ip route 10.10.10.0 255.0.0.0 30.30.30.1
The above returns inconsistent address and mask error for R3 :
7 Replies 7
If the network is a /8, then the network-address that you have to use in the "ip route" statement ist 10.0.0.0:
ip route 10.0.0.0 255.0.0.0 30.30.30.1
pwwiddicombe
Level 4
Level 4
R2 and R3 both have identical IP addresses?  that probably won't do what you want !
(30.30.30.1/24).  Did you intend one to be 30.30.30.2/24 for one of them, maybe ?
edited
PS - if you aren't running a routing protocol, you'll also need a static on R1, to get to the other 2 routers, for the 30.30.30.0/24 network.  Even pings from R3 to R1 would fail, as the packet would make it R3->R1, but there wouldn't be a return path.
(Unless you happened to have ip proxy-arp enabled on R2).
Ganesh Hariharan
R3 :  30.30.30.2 /24
R1:10.10.10.1 /8
Either you do proper subnetting for your destination network and do routing configuration, As 10.10.10.1 will fall under 10.0.0.0/8 ..so put route for 10.0.0.0/8 on your R3 towards R2 and check the connectivity.
Hope it Helps..
-GI
hi
How come 10.10.10.10/24 comes under /8 network. ? I thought that i am implementing classless routing
Yes, you need either
R3:ip route 10.0.0.0.0 255.0.0.0 30.30.30.1
or   ip route 10.10.10.0 255.255.255.0 30.30.30.1
You can't effectively "wildcard out" in the subnet mask and include all the details, as it doesn't make sense.
