Inconsitency check in N2K acces port
josecardenas
We have configured a Fex port as acces port but the port no up becouse appear in suspended state, i think the problem is a vlan mistmach as appear in the consistence-parameter information but i not found in what part allow the correct vlan, the N2K are connected to 2 N5K, and 5K are connected to2  N7K
%ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 41 on Interface Ethernet101/1/48 are being susp
ended. (Reason: Vlan is not configured on remote vPC interface)
show vpc consistency-parameters interface e101/1/48
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
Speed                       1     1000 Mb/s              1000 Mb/s
Duplex                      1     full                   full
Port Mode                   1     access                 access
MTU                         1     1500                   1500
Admin port mode             1
Shut Lan                    1     No                     No
Allowed VLANs               -     41                     1
Local suspended VLANs       -     -                      -
krahmani323
Level 3
Level 3
Hello Jose,
In order to activate the VLAN on your N2K host interface, you will need to implement the same configuration for port Ethernet101/1/48 on the Second N5k /peer (switchport access vlan 41….).
Indeed many configuration and operational parameters must be identical on BOTH Nexus N5k for the consistency (interface 101/1/48 config si one of those). It is very important to have this global consistency between the two N5K peers (confugurations of the VPC – Vpc peer-link – N2K host interfaces….)
This behaviour (vlan suspended for the interface) is the expected one : It is considered as Type 2 inconsistency mismatch to prevent undesired forwarding.
A recent feature introduced in NXOS 5.0(2)N1(1) called configuration synchronization (config-sync) allows you to configure one switch profile and have the configuration be automatically synchronized to the peer switch.
Best regards.
Karim
josecardenas
Thanks Karim
Please recomend me a document to review the conf-syncoption.
Thanks and regards,
José
Hi José,
The link describing the config-sync feature is the following :
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/operations/n5k_config_sync_ops.html
You will find all the details (Guidelines, limitations, details per architectures, configuration example and so on..)
Hope that helps.
Best regards.
Kind regards.
Karim
