Incrementing throttles and ignored Vlan
spinning2008
Hi all,
I have a Cisco WS-C2950-48,  and I have incrementing throttles and ignored on  VLAN 1 interface.  Vlan 1 is a managament interface, some time
when I try to Access I can't.
2950#show int vlan 1
Vlan1 is up, line protocol is up
  Internet address is 10.0.0.146/16
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Last input 00:00:00, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 36000 bits/sec, 52 packets/sec
  30 second output rate 17000 bits/sec, 23 packets/sec
     297870558 packets input, 1596814696 bytes, 0 no buffer
     Received 195554838 broadcasts (0 IP multicast)
     0 runts, 0 giants, 1607875 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 98455174 ignored
     76743540 packets output, 3185572576 bytes, 0 underruns
     0 output errors, 2 interface resets
Clients are not having any troubles.
CPU utilization it's OK.
Thanks in advance.
