input discard error on n7k interface
Asim Afzal
Server is connected to  two nexus 7k using VPC.I am seeing input discard error on the interface
Can any body advise why  input discard error is increasing
Nexus 1
NEXUS7K-1# sh int e 14/20
Ethernet14/20 is up
admin state is up, Dedicated Interface
  Belongs to Po1820
  Hardware: 1000/10000 Ethernet, address: b838.61b8.7c63 (bia b838.61b8.7c63)
  Description: ****** MAM-IMEX-03 VLAN_12 ****
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  reliability 255/255, txload 1/255, rxload 4/255
  Encapsulation ARPA, medium is broadcast
  Port mode is access
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Auto-Negotiation is turned on
  Input flow-control is off, output flow-control is off
  Auto-mdix is turned off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  EEE (efficient-ethernet) : n/a
  Last link flapped 3d09h
  Last clearing of "show interface" counters 1w5d
  5 interface resets
  30 seconds input rate 162892448 bits/sec, 13494 packets/sec
  30 seconds output rate 75368 bits/sec, 40 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 22.72 Mbps, 1.87 Kpps; output rate 87.75 Kbps, 27 pps
  RX
    4722536902 unicast packets  126282 multicast packets  1040 broadcast packets
    4722660780 input packets  6937040338942 bytes
    0 jumbo packets  0 storm suppression packets
    20 runts  0 giants  4 CRC  0 no buffer
    24 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  306997 input discard
    0 Rx pause
  TX
    885319693 unicast packets  18325611 multicast packets  4639140 broadcast packets
    908280976 output packets  388758590992 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
******************************************************8
Nexus 2
Nexus7K-2# sh int e12[J[J14/20
Ethernet14/20 is up
  Belongs to Po1820
  Hardware: 1000/10000 Ethernet, address: c08c.60af.f3ff (bia c08c.60af.f3ff)
  Port mode is access
  EtherType is 0x8100
  4 interface resets
  30 seconds input rate 26360 bits/sec, 13 packets/sec
  30 seconds output rate 65592 bits/sec, 33 packets/sec
    input rate 27.22 Kbps, 2 pps; output rate 67.90 Kbps, 25 pps
  RX
    3289525772 unicast packets  138738 multicast packets  19343 broadcast packets
    3289712832 input packets  4858618378664 bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 input with dribble  60988 input discard
    0 Rx pause
  TX
    1721271093 unicast packets  22194874 multicast packets  2877112 broadcast packets
    1746339610 output packets  2252252433048 bytes
    0 jumbo packets
    0 Tx pause
NEXUS7K-1# sh ver
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2012, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Software
  BIOS:      version 2.8.0
  kickstart: version 6.1(1)
  system:    version 6.1(1)
  BIOS compile time:       06/09/12
  kickstart image file is: bootflash:///n7000-s2-kickstart.6.1.1.bin
  kickstart compile time:  6/26/2012 0:00:00 [08/10/2012 04:18:43]
  system image file is:    bootflash:///n7000-s2-dk9.6.1.1.bin
  system compile time:     6/26/2012 0:00:00 [08/10/2012 05:17:45]
Hardware
  cisco Nexus7000 C7018 (18 Slot) Chassis ("Supervisor module-2")
  Intel(R) Xeon(R) CPU         with 12225164 kB of memory.
  Processor Board ID JAF1631ARQB
  Device name: NEXUS7K-1
  bootflash:    1966080 kB
  slot0:              0 kB (expansion flash)
Kernel uptime is 488 day(s), 0 hour(s), 50 minute(s), 25 second(s)
Last reset
  Reason: Unknown
  System version: 6.1(1)
  Service:
plugin
  Core Plugin, Ethernet Plugin
InayathUlla Sharieff
Could you please go through the below link and  check if this helps.
https://supportforums.cisco.com/discussion/10982271/nexus-7k-3750g-vpc-high-input-discards-rx-side
If no then capture the outputs suggested in the link and share the same.
There is a known issue that allowed vlan miss match causes "input discards" on nexus side.
Incoming traffic that has dot1q tag which is not allowed at nexus side is accounted in "input discard".
Inayath
