Installing Cisco 1711 - Issue routing between FE0 and VLAN1 ports
james.curran
I have been tasked with bridging two segments in our internal structure. I have been given the 1711 to accomplish this task. all segments are used strickly within the organization and no internet access is needed or desired.
My test bed
desktop 192.9.100.250/24------->Vlan1 Port 4 with vlan1 at 192.9.100.194 ----->FastEthernet0 in 1711 at 156.52.42.194 ----------> Desktop 156.52.42.10
I can successfully ping from 192.9.100.250 to the Desktop 156.52.42.10
Pinging from the 156.52.42.10 Desktop to the 192.9.100.250 is unsuccessful
pinging from 156.52.42.10 to 192.9.100.194 shows a reply from 156.52.42.194 only
I messed up the access-list maybe?
  We use NAT for many reasons. If you have no internet access , just do a routing between networks. It's okay.
HTH,
Toshi
13 Replies 13
   It's a NAT problem. Do you want to use NAT in this case? If not, just try the following command.
interface Vlan1
no ip nat inside
interface FastEthernet0
no ip nat outside
HTH,
Toshi
Thanks for the fast responce
I entered the statements but still cannot access the 192.9.100.250 desktop from the 156.52.42.10 desktop
The reverse trip works fine. Pings like a champ. I just cannot get the packet to across or to the 194.9.100.194 barrier.
Any help is appreciated.
  Can you ping from 156.52.42.10 to 192.9.100.194?
  Please post the configuration you modify and the output of "show ip route" command?
Toshi
When i ping from the 156.52.42.10 desktop to the 192.9.100.194 Vlan address on the router
it returns "reply from 156.52.42.194
Pinging 192.9.100.194 with 32 bytes of data:
Reply from 156.52.42.194: bytes=32 time=3ms TTL=255
Reply from 156.52.42.194: bytes=32 time=8ms TTL=255
Reply from 156.52.42.194: bytes=32 time=1ms TTL=255
Ping statistics for 192.9.100.194:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 1ms, Maximum = 8ms, Average = 3ms
Why did it bounce back like that----This is with NAT inside/outside set up again.
With NAT disabled per your last e-mail
C:\Documents and Settings\curran>ping 192.9.100.194
Reply from 192.9.100.194: bytes=32 time=2ms TTL=255
Reply from 192.9.100.194: bytes=32 time=8ms TTL=255
Reply from 192.9.100.194: bytes=32 time=1ms TTL=255
C:\Documents and Settings\curran>ping 192.9.100.250
Pinging 192.9.100.250 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.9.100.250:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
   Okay, Can you ping 192.9.100.250 from the router? Please post the output of ping commands below.
   Router#ping 192.9.100.250
   Router#ping 192.9.100.250 source Fastethernet0
   it might be a personal firewall problem.
Toshi
here are results
again thanks for the assist
   If desktop-192.9.100.250 has been configured a gateway as 192.9.100.194, I think this is a personal firewall problem.
   You just turn off a personal firewall/window fireall on desktop for testing.
HTH,
Toshi
Turned off firewall on 192.9.100.250
no change in ping from 156.52.42.10 no answer
I can ping 192.9.100.250 desktop from Fastethernet0 but not from the 156.52.42.10 system
since my last responce I remembered that I had reenabled NAT again on the interfaces.
Turned of natting and it is working. I can ping 192.9.100.250 desktop from the 156.52.42.10 desktop fine.
reversing the ping works as well.
Must have been that firewall GRRRR. I hope my hair grows back.
Thank you very much. I will test somemore and respond soon.
   Edit: Okay it seems to work now.  Next lab should be NAT.
Toshi
Here is running-config
If it runs without Nat do I still need it since it is for internal use
only?
HTH,
Toshi
It will be used internally from some older units in an incinerator by fiber to a headoffice Cisco 3560 (152.52.42.194)
It could not see the 192.x.x.x from the 156.x.x.x .
