Installing IOS on a C6509 currently running CatOS
aghufran
I want to install IOS on a Cat6509 currently running CatOS. Following are the module and current image details on it. I do not want to retain the config so no need to convert that. I just need to install CatOS. Please advise on what is the procedure as so far the procedures I have come across are to convert it from Hybrid to Native and then from Native to IOS. I am thinking if this should be a straight forward process to just download the IOS image and change the bootvar to use that.
Abid Ghufran.
Console> (enable) sh module
Mod Slot Ports Module-Type               Model               Sub Status
2   2    2     1000BaseX Supervisor      WS-X6K-SUP2-2GE     yes ok
16  2    1     Multilayer Switch Feature WS-F6K-MSFC2        no  ok
Mod  Sub-Type                Sub-Model           Sub-Serial  Sub-Hw Sub-Sw
2    L3 Switching Engine II  WS-F6K-PFC2         SAL08186L3X 3.4
Console> (enable) dir
-#- -length- -----date/time------ name
  1 10807980 Dec 03 2007 18:42:35 cat6000-sup2k9.8-6-3.bin
20791748 bytes available (11189820 bytes used)
Console> (enable) sh boot
BOOT variable = bootflash:cat6000-sup2k9.8-6-3.bin,1;
Reza Sharifi
Follow this document to convert from Catos to IOS. It has step-by-step instructions.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/12031-catos-ios-conversion-6500k.html
Thanks Reza.
Let me try that and come back with how it goes.
Abid Ghufran.
