Inter operability
navneet-k1
Level 2
Level 2
Is there any compatibility issue if I use Cisco 9300 with TpLINK switches?
I am planning to use Cisco 9300 as core switch and Tplink switches as distribution switch.
Reza Sharifi
Unmanaged TP-link switches usually work fine with Cisco switches, but if you are planning on deploying multiple managed switches with multiple VLANs, get one and test it first.
