10-21-2015 06:51 AM - edited 03-08-2019 02:18 AM
I currently have 2 Nexus 9396 switches (Layer 3 core) and several Catalyst 3850 access layer 2 switches.
I have several users (not all) where inter vlan communication will drop. It happens for about a minute then corrects itself. This may happen a handful of times per day, but not everyday. Very inconsistent.
During my troubleshooting, I am able to access resources on my current VLAN but no other VLANs. I also can not ping the gateway.
Your help is appreciated.
10-21-2015 07:30 AM
I currently have 2 Nexus 9396 switches (Layer 3 core) and several Catalyst 3850 access layer 2 switches. I have several users (not all) where inter vlan communication will drop. It happens for about a minute then corrects itself. This may happen a handful of times per day, but not everyday. Very inconsistent. During my troubleshooting, I am able to access resources on my current VLAN but no other VLANs. I also can not ping the gateway. Your help is appreciated.
If N9k is doing Core functionality and having all SVI configured , Could you check what show logging output showing in N9k and what is the show spanning tree vlan output for problematic vlan.
-GI
10-21-2015 07:40 AM
There are no recent logs. The last one was from Oct 13th. We were having the issue yesterday. Below is the spanning tree info:
VLANxxx
Spanning tree enabled protocol rstp
Root ID Priority 24677
Address xxxxxxxxxxxx
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 24677 (priority 24576 sys-id-ext 101)
Address xxxxxxxxxxxxxx
Interface Role Sts Cost Prio.Nbr Type
Po1 Desg FWD 1 128.4096 (vPC peer-link) Network P2p
Po2 Desg FWD 1 128.4097 (vPC) P2p
Po3 Desg FWD 1 128.4098 (vPC) P2p
Po4 Desg FWD 1 128.4099 (vPC) P2p
Po5 Desg FWD 1 128.4100 (vPC) P2p Peer(STP)
Po6 Desg FWD 1 128.4101 (vPC) P2p
Eth1/30 Desg FWD 2 128.286 P2p
Eth1/31 Desg FWD 2 128.287 P2p
Eth1/32 Desg FWD 2 128.288 P2p
10-21-2015 08:46 AM
There are no recent logs. The last one was from Oct 13th. We were having the issue yesterday. Below is the spanning tree info: VLANxxx Spanning tree enabled protocol rstp Root ID Priority 24677 Address xxxxxxxxxxxx This bridge is the root Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Bridge ID Priority 24677 (priority 24576 sys-id-ext 101) Address xxxxxxxxxxxxxx Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Interface Role Sts Cost Prio.Nbr Type ---------------- ---- --- --------- -------- -------------------------------- Po1 Desg FWD 1 128.4096 (vPC peer-link) Network P2p Po2 Desg FWD 1 128.4097 (vPC) P2p Po3 Desg FWD 1 128.4098 (vPC) P2p Po4 Desg FWD 1 128.4099 (vPC) P2p Po5 Desg FWD 1 128.4100 (vPC) P2p Peer(STP) Po6 Desg FWD 1 128.4101 (vPC) P2p Eth1/30 Desg FWD 2 128.286 P2p Eth1/31 Desg FWD 2 128.287 P2p Eth1/32 Desg FWD 2 128.288 P2p
With problem description what you have shared , i can sense either sep convergence is happening on the VLAN. Have you seen any link flaps in core 9K or in any of the access layer switches.
vPC between the N9k are showing correct output and you don't really see any logs on N9k.
-GI
