inter vlan doesn't ping to router
bearjew91
Hi, i am new with cisco and i bump into the same problem for the second time now. i have 2 switches each has a vlan with two pc's i enabled trunk ports and inter vlans in the router and it works fine in the first 2 switches but in the third for some reason no ping and same happened to me before with 2working and the 3rd not.any suggestions?subneting.jpg
to solve your issue, you need to create vlan 30 on switch 1 & 2 and please configure gi0/2 on switch 1 to be a trunk as well.
Krash Mole
Please share your pkt file...
thanks a lot i knew it was going to be something simple...
