Inter Vlan Routing is not working
Hello everyone. I am trying to get two vlans talk to each other and despite so much effort and time I have put into this, it's not working. The scenario is very simple. I have created two vlans on my Cisco 3550 Catalyst switch and using one Cisco 2811 router. Created two sub-interfaces off one fast Eth 0/0 on my Router. I am also posting my configuration below. Please help me guys. Thanks in advance.
Switch:
Switch#sh run
Building configuration...
Current configuration : 2254 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
ip ssh time-out 120
ip ssh authentication-retries 3
vtp mode transparent
spanning-tree mode pvst
vlan 10
name DATA
vlan 20
name VOICE
interface FastEthernet0/1
switchport trunk allowed vlan 10,20
switchport mode trunk
interface FastEthernet0/2
switchport mode dynamic desirable
interface FastEthernet0/3
switchport access vlan 10
switchport mode access
spanning-tree portfast
interface FastEthernet0/4
interface FastEthernet0/5
switchport access vlan 20
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
ip classless
ip http server
line con 0
line vty 5 15
end
Router:
interface FastEthernet0/0
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
interface FastEthernet0/1.10
encapsulation dot1Q 10
ip address 10.10.10.254 255.255.255.0
interface FastEthernet0/1.20
encapsulation dot1Q 20
ip address 10.10.20.254 255.255.255.0
10 Replies 10
Richard Burts
I have looked through the posted configs and do not see any obvious issues. Can you verify that switch port Fast0/1 connects to router interface Fast0/1? Can you verify that PCs are connected to switch ports Fast0/3 and Fast0/5? Can you post for both PCs the interface IP, mask, and gateway? Can you post the output of show interface status from the switch? Can you post the output of the commands show ip interface brief, show ip route, and show arp from the router?
Rick
Rick
Hello rick. thanks for your quick response. Yes the Fa 0/1 from switch is connected to Fa 0/1 on router. Yes PCs are connected to Fa 0/3 and 0/5 on Switch. Pc1:
IP 10.10.10.11, mask 255.255.255.0, DG 10.10.10.254.
PC2: IP 10.10.20.30. SM 255.255.255.0 DG 10.10.20.254.
Show Interface Status:
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: 10,20
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: negotiate
Operational Trunking Encapsulation: native
Negotiation of Trunking: Off
Access Mode VLAN: 10 (DATA)
Voice VLAN: none
Trunking VLANs Enabled: ALL
Protected: false
Switchport: Enabled
Access Mode VLAN: 20 (VOICE)
Voice VLAN: none
Protected: false
Router1#sh ip interface brief
FastEthernet0/0 unassigned YES manual up down
FastEthernet0/1 unassigned YES manual up up
FastEthernet0/1.10 10.10.10.254 YES manual up up
FastEthernet0/1.20 10.10.20.254 YES manual up up
Serial0/1/0 unassigned YES unset administratively down down
Serial0/1/1
Router1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
10.0.0.0/24 is subnetted, 2 subnets
C 10.10.10.0 is directly connected, FastEthernet0/1.10
C 10.10.20.0 is directly connected, FastEthernet0/1.20
Router1#sh arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 10.10.10.11 17 3c97.0ee9.165b ARPA FastEthernet0/1.10
Internet 10.10.10.254 - 0026.cbdb.14e1 ARPA FastEthernet0/1.10
Internet 10.10.20.30 3 685b.35c8.e67d ARPA FastEthernet0/1.20
Internet 10.10.20.254 - 0026.cbdb.14e1 ARPA FastEthernet0/1.20
My other PC is MAC and it can ping 10.10.10.11 which is a Win 10 PC.......could that be the issue???
With symptoms like this I would look at the possibility of a firewall on the PC that is denying ping.
Rick
Rick
I have Norton Internet security installed on my Pc and I have already disabled the firewall..but the ping is still not going through....However my MAC can ping through.
Of the output that you posted I find this one particularly helpful
Router1#sh arp
It clearly shows that the router is successfully communicating with both devices. If ping works one way and not the other way it is not a routing issue. I am convinced that there is something on the host that is impacting ping. There might be one way traffic if there were access lists on interfaces evaluating traffic, or if there were some device doing stateful inspection (like a firewall). But the description of the situation does not indicate either of these possibilities. I say check more carefully on the PC.
Rick
Rick
I agree with Rick, the config looks by the book. Is this a live network or a simulator ? You might want to try and change the native VLAN as below:
Switch
switchport trunk native vlan 10
Router
encapsulation dot1Q 10 native
Hello Georg. I tried that but no change in output. My Pc's are pinging the gateway but not the other pc in different vlan or another another gateway.
are you doing this in Packet Tracer ? If so, post the project file (you need to zip it first)...
No I am doing this on a live Cisco router and a Cisco Switch.
