Inter Vlan Routing NAT
heiko.sterner
Dear Techies,
I have built a switch3550 and router2811 configuration for Inter Vlan routing with NAT to my ISP
from the switch/router themselves i can ping anything inside the vlans and any other configured IPs on the switch/router side,
my only problem is that i cant ping outside addresses with my two clients which are connected on separate vlans.
1st i will list up the used ports on the devices then you will find the startup-config for 2811/3550, thanks in advance,
2811:
int fa0/0 goes to ISP network which is a usual LAN with Gateway 192.168.1.1
int fa0/1  is trunk to switch 3550
int fa0/1.1 is sub Int Vlan2
int fa0/1.2 is sub int Vlan3
3550:
int fa0/1 Mng. Port
int fa0/2 Vlan2, win10 Laptop, static address 192.168.2.100/24 default Gateway 192.168.2.10
int fa0/47 Vlan3, Laptop, static address 192.168.3.100/24 default Gateway 192.168.3.10
int fa0/48 Trunk to 2811 - sub int
2811:
Current configuration : 1163 bytes
version 12.3
service config
hostname hjs2811
boot-start-marker
boot-end-marker
no logging console
no network-clock-participate aim 0
no network-clock-participate aim 1
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
interface FastEthernet0/0
 ip address dhcp
 ip nat outside
 duplex full
 speed auto
interface FastEthernet0/1
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/1.1
 encapsulation dot1Q 2
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
interface FastEthernet0/1.2
 encapsulation dot1Q 3
 ip address 192.168.3.1 255.255.255.0
 ip nat inside
interface Serial0/2/0
 no ip address
 shutdown
 clockrate 2000000
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
ip nat inside source list 101 interface FastEthernet0/1 overload
access-list 101 permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
 login
scheduler allocate 20000 1000
end
3550:
Current configuration : 6719 bytes
version 12.2
no service pad
hostname
no logging console
no aaa new-model
ip subnet-zero
ip routing
crypto pki trustpoint TP-self-signed-696064512
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-696064512
revocation-check none
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
no switchport
ip address 192.168.1.131 255.255.255.0
interface FastEthernet0/2
switchport access vlan 2
switchport mode access
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
switchport access vlan 3
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
switchport trunk native vlan 80
switchport trunk allowed vlan 2,3
switchport mode trunk
interface GigabitEthernet0/1
switchport mode dynamic desirable
interface GigabitEthernet0/2
interface Vlan1
ip address 192.168.4.1 255.255.255.0
interface Vlan2
description T61
ip address 192.168.2.10 255.255.255.0
interface Vlan3
description X230
ip address 192.168.3.10 255.255.255.0
ip classless
ip route 192.168.2.0 255.255.255.0 192.168.1.0
ip route 192.168.2.0 255.255.255.0 192.168.1.1
ip route 192.168.3.0 255.255.255.0 192.168.1.0
ip route 192.168.3.0 255.255.255.0 192.168.1.1
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
login
line vty 5
login
end
Are you able to ping the respective gateways from the computers?
I think I found the problem, you ip nat outside is configured under the interface fa0/0 but you have configured the NAT statement with f0/1
so you should have
ip nat inside source list 101 interface FastEthernet0/0 overload
remove the previous NAT statement and create the new one with FastEthernet 0/0.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
10 Replies 10
Reza Sharifi
According to your post, the router sub-interfaces are 2.1 and 3.1, so why are the Laptops default gateways pointed to 2.10 and 3.10?
Can you clarify?
I used 2.10, 3.10 as default gateway for testing the InterVlan Routing on my Layer 3 Switch,
changing the default gateways from 2.10 >2.1 and 3.10 >3.1 does not bring any changes
please find bellow ---sh ip route--- and --sh ip int brief-- from the 3550/2811
BIG THX for your quick reply,
hjs3550#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
C    192.168.1.0/24 is directly connected, FastEthernet0/1
C    192.168.2.0/24 is directly connected, Vlan2
C    192.168.3.0/24 is directly connected, Vlan3
S*   0.0.0.0/0 [1/0] via 192.168.1.1
_________________________________________________
Vlan1 192.168.4.1 YES manual up down
Vlan2 192.168.2.10 YES NVRAM up up
Vlan3 192.168.3.10 YES NVRAM up up
FastEthernet0/1 192.168.1.131 YES NVRAM up up
FastEthernet0/2 unassigned YES unset up up
FastEthernet0/3 unassigned YES unset down down
FastEthernet0/4 unassigned YES unset down down
FastEthernet0/5 unassigned YES unset down down
FastEthernet0/6 unassigned YES unset down down
FastEthernet0/7 unassigned YES unset down down
FastEthernet0/8 unassigned YES unset down down
FastEthernet0/9 unassigned YES unset down down
FastEthernet0/10 unassigned YES unset down down
FastEthernet0/11 unassigned YES unset down down
FastEthernet0/12 unassigned YES unset down down
FastEthernet0/13 unassigned YES unset down down
FastEthernet0/14 unassigned YES unset down down
FastEthernet0/15 unassigned YES unset down down
FastEthernet0/16 unassigned YES unset down down
FastEthernet0/17 unassigned YES unset down down
FastEthernet0/18 unassigned YES unset down down
FastEthernet0/19 unassigned YES unset down down
FastEthernet0/20 unassigned YES unset down down
FastEthernet0/21 unassigned YES unset down down
FastEthernet0/22 unassigned YES unset down down
FastEthernet0/23 unassigned YES unset down down
FastEthernet0/24 unassigned YES unset down down
FastEthernet0/25 unassigned YES unset down down
FastEthernet0/26 unassigned YES unset down down
FastEthernet0/27 unassigned YES unset down down
FastEthernet0/28 unassigned YES unset down down
FastEthernet0/29 unassigned YES unset down down
FastEthernet0/30 unassigned YES unset down down
FastEthernet0/31 unassigned YES unset down down
FastEthernet0/32 unassigned YES unset down down
FastEthernet0/33 unassigned YES unset down down
FastEthernet0/34 unassigned YES unset down down
FastEthernet0/35 unassigned YES unset down down
FastEthernet0/36 unassigned YES unset down down
FastEthernet0/37 unassigned YES unset down down
FastEthernet0/38 unassigned YES unset down down
FastEthernet0/39 unassigned YES unset down down
FastEthernet0/40 unassigned YES unset down down
FastEthernet0/41 unassigned YES unset down down
FastEthernet0/42 unassigned YES unset down down
FastEthernet0/43 unassigned YES unset down down
FastEthernet0/44 unassigned YES unset down down
FastEthernet0/45 unassigned YES unset down down
FastEthernet0/46 unassigned YES unset down down
FastEthernet0/47 unassigned YES unset up up
FastEthernet0/48 unassigned YES unset up up
GigabitEthernet0/1 unassigned YES unset down down
GigabitEthernet0/2 unassigned YES unset down down
_______________________________________________________
hjs2811>sh ip route
C    192.168.1.0/24 is directly connected, FastEthernet0/0
C    192.168.2.0/24 is directly connected, FastEthernet0/1.1
C    192.168.3.0/24 is directly connected, FastEthernet0/1.2
hjs2811>
__________________________________________________________________________
hjs2811>sh ip int brief
FastEthernet0/0 192.168.1.118 YES DHCP up up
FastEthernet0/1 unassigned YES NVRAM up up
FastEthernet0/1.1 192.168.2.1 YES NVRAM up up
FastEthernet0/1.2 192.168.3.1 YES NVRAM up up
Serial0/2/0 unassigned YES NVRAM administratively down down
hjs2811>
Please check my comment above.
Additional to Reza's comment, if you are trying to ping a domain example: www.domain.com, check the DNSs configured on the computers, otherwise you could try ping with the public IP, example: 8.8.8.8.
Also you could remove the following lines, because your switch is working as layer 2 ony.
i only can ping public IPs direct from my switch/router cli !
my switch has ip routing enabled and processes as layer 3 device,
can it cause conflicts with sub-int?
 configured the DNS on my clients with IP 192.168.1.1 which is my ISP Router,
i guess thats correct?
No, the IP routing could not generate any problem, but if the router is making the routing you dont need the ip routing enabled and static routes either, because you have a router-in-a-stick scheme.
So I recommend to use the following DNS for testing.
Primary 8.8.8.8
Secondary 4.2.2.2
They are Public Google DNS
if i make google dns entries to my clients it doesnt change anything,
the 1st Problem is that i cant ping my ISP home router from my clients,
that has nothing to do with DNS entrie so far
static Ip - netmask - dfltgway entries should be enough to ping the ISP router,
like i said before i can ping public domains like www.google.com
from my Cisco Switch / Router,
so you should have
good boy ;-P
inverse/reverse thinking error by me!!!
is the correct answer !!!
piiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiing :))))
hahahaha Good to know it was resolved  :-)
have a great day my friend.
