Inter-vlan routing on WS-C3650-24PS-L
zineeddine.b
We have a WS-C3650-24PS-L Lan base switch.
Is it possible to do Inter-Vlan routing without using a router on a stick?
Regards.
Mark Malone
looks like just static routing , ip base will get you basic routing
The Cisco Express Forwarding hardware routing architecture delivers extremely high-performance IP routing in the Cisco Catalyst 3650 Series Switches:
   IP unicast routing protocols (static, Routing Information Protocol Version 1 [RIPv1], and RIPv2, RIPng, Enhanced Interior Gateway Routing Protocol [EIGRP] stub) are supported for small-network routing applications with the IP Base feature set. Limited static routing with the LAN Base feature set. Equal-cost routing facilitates Layer 3 load balancing and redundancy across the stack.
Thank you for your replay.
I read in cisco documentation that the static routes are limited to 16. is that right ?
yes that's about right as it 16 on 3750s with lanbase
