Inter VLAN routing trouble
ryangibbons84
Sorry, the discussions dont support pkt files so I changed the extension on it. But I have included a JPEG to help visualize where I'm at. But also my router and switch configuration:
CORP Router config:
Current configuration : 1451 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname CORP
no ip cef
no ipv6 cef
no ip domain-lookup
interface FastEthernet0/0
description link to 3560 switch
ip address 172.31.1.5 255.255.255.252
duplex auto
speed auto
interface Serial0/0
description link to ISP
ip address 192.31.7.6 255.255.255.252
interface Serial0/1
no ip address
clock rate 2000000
shutdown
interface FastEthernet1/0
no ip address
duplex full
speed auto
interface FastEthernet1/0.1
description Management VLAN 1 - Native VLAN
encapsulation dot1Q 1 native
interface FastEthernet1/0.10
description Sales VLAN 10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface FastEthernet1/0.20
description Engineering VLAN 20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface FastEthernet1/0.30
description Marketing VLAN 30
encapsulation dot1Q 30
ip address 192.168.30.1 255.255.255.0
interface FastEthernet1/1
no ip address
duplex auto
speed auto
shutdown
router eigrp 10
network 192.168.1.0
network 192.168.10.0
network 192.168.20.0
network 192.168.30.0
network 172.31.0.0
network 192.31.7.0
no auto-summary
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Switch 2 Config:
Current configuration : 1784 bytes
version 12.2
hostname Switch2
no ip domain-lookup
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
switchport access vlan 20
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
switchport access vlan 30
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
description Trunk Link To CORP Router
switchport mode trunk
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 192.168.1.2 255.255.255.0
ip default-gateway 192.168.1.1
line con 0
line vty 0 4
login
line vty 5 15
login
end
Hello
What is your issue?
res
Paul
Kind Regards
Paul
