Inter vlan routing
Rafael Jimenez
Level 7
Level 7
I had to configure several vlans on a CAT4510, all vlan had to see the server vlan. The customer dont want that one vlan see other vlans (only with the servers vlan).
How can I do this?
6 Replies 6
m-haddad
Level 9
Level 9
You can create an ACL and apply inbound on each VLAN interface. In the ACL allow communication to the servers subnet and deny everything else to the RFC 1918 networks.
Hope this helps,
Appreciate you rating,
ok, what about CPU usage?.
Is possible use VLAN MAPS (VLAN ACL)?.
Hi, can you tell me if this work in this way...
ip access-list extended intervlan_2_3_acl
permit ip 192.168.2.0 0.0.0.255 192.168.3.0 0.0.0.255
vlan access-map intervlan_map
match ip address intervlan_2_3_acl
action drop
ip access-list extended intervlan_2_4_acl
permit ip 192.168.2.0 0.0.0.255 192.168.4.0 0.0.0.255
match ip address intervlan_2_4_acl
action drop
ip access-list extended intervlan_others_acl
permit ip any any
match ip rest-intervlan_acl
action forward
vlan filter intervlan_map vlan-list 1-4
thanks
doing some research.. I believe this will work better...
ip access-list extended intervlan_1_acl
permit ip 192.168.1.0 0.0.0.255 any
permit any ip 192.168.1.0 0.0.0.255
vlan access-map intervlan_1_map
match ip address intervlan_1_acl
action drop
action forward
vlan filter intervlan_1_map vlan-list 1
let me give small note:
normal acl routed acl RACL
used to control traffic between vlans in a switch
while vlan ACL VACL as u referd it vlan map this can be used between vlans but it is useful to filter traffic withing the same vlan as well
in ur case u can creat normal ACL RACL that filter traffic between vlans and apply it on the vlan interface on ur L3 switch on the SVI
like interface vlan x
access-group in .....
if helpful Rate
The above will deny any traffic to anywhere from 192.168.1.0/24. I don't think this is your target. You said you want to deny intervlan traffic right? Not everything from that VLAN?
