Inter VLAN Routing
naveen.bodhula1
Consider the picture Attached
I want to make Inter VLAN between to switches using a Router.
when trying to use subinterfaces using this CLI command:
interface FastEthernet0/0.1
encapsulation dot1Q 10
ip address 10.0.0.1 255.0.0.0
interface FastEthernet0/0.2
encapsulation dot1Q 20
ip address 10.0.0.20 255.0.0.0
But when I give IP Address for fa0/0.2 it is showing "10.0.0.0 is overlapping with interface fa0/0.1"
Can't I give same network for different Subinterfaces???
and How can I configure InterVALN for this Design?
Thanks in Advance
Reza Sharifi
That is the correct behavior.  You can't use the same subnet for 2 different sub-interfaces.
Each sub-interfaces needs to be in its own subnet,
ip address 10.0.0.1 255.255.255.0
ip address 10.0.1.20 255.255.255.0
Thanks for the reply,
But still it didn't worked showing same error '10.0.0.0 is overlapping with interface fa0/0.1'
