inter vlan routing
jonk34567
Level 4
Level 4
In the below topology if i need to route between each and every vlan what are the commands i should enter ?
Mark Malone
Hi Jonk in that topolgy the router should take care of all layer 3 routing , as its L3 capable ,it wil allow intervlan routing by default or if not make sure ip routing command is in place but thats a default command in routers so should be there
Once the l3 interface or vlan sub interfaces exist on the router i t will allow themto communicate by default
the switch would be layer 2 up to the router and the router will take care of the rest
Julio E. Moisa
In this scheme all the VLANs are going to be able to communicate between each others, because their gateways are configured on the same router, you don't have to submit any command.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
