Inter-VLAN Routing
sandro1
Community Member
I was wondering what the purpose of Inter-VLAN routing is. Of course, it enables you to communicate with other VLANs.
In a simple example:
VLAN 10
VLAN 20
VLAN 30
Let's say Inter-VLAN routing should be enabled for VLAN 10 and VLAN 20 because those two networks need to communicate with each other. What's the purpose of having two separate VLANs after all? I might just consolidate those VLANs into one VLAN?
But maybe my other question might resolve my problem.
Given the network (see attachment).
All VLANs need to communicate with the two server clusters. Since there are different VLANs they cannot communicate with them right out of the box. I suppose this is when Inter-VLAN routing comes into play?
What's a good approach / best practice in this scenario?
I thought of making trunks between the switches and the servers too, and assign the servers to each VLAN?
help:)
ps. this is not a production environment. I'm just a student.
Sandro
luis_cordova
Hi @sandro1 ,
A:The purpose of VLANs is to separate the diffusion domains.
For example, in the same building you can have several diffusion domains working on the same LAN.
These domains could be:
-Administrators
-Employees
-Visits
-Support
-Services
You can connect several of these domains to the same switch and separate them through the VLANs.
Then, you can choose which VLAN you want to communicate with another through the inter-vlan.
A: Correct, as the inter-vlan will also provide a gateway address to the VLAN through sub-interfaces.
A: I recommend creating a different vlan for Cluster1 servers and another for Cluster2 servers.
Leave the switch ports in access mode, which connect to PCs and servers, and assign them the corresponding vlan.
In addition, you must leave in trunk mode all interfaces between the switches and those that connect the switches with the routers.
Then, configure sub-interfaces for vlan10, 20, 30 and the two new ones (vlan for cluster 1 and 2) in Router1.
As you have only one router, it will be enough to have the inter-vlan ready so there is communication between the vlan.
If you want to limit access between some vlan, you can achieve it through ACL.
Joseph W. Doherty
One major reason for having multiple VLANs (besides those mentioned by Luis) is for scalability. Within a single L2 domain, broadcasts are used for various purposes and broadcasts are sent to all hosts and all hosts must examine the content of the broadcast. Generally, because of broadcasts you only want about 128 (/25) to 512 (/23) hosts per L2 domain. By default, routing does not forward broadcasts.
Edwin Portillo
When in your company or infrastructure are handled different areas for example: HR, Employees, Management is important to separate the resources that correspond, for example, data shared only by the Management and HR for the hiring of personnel or in the amount of decisions, Employees are not allowed to make decisions for them are other resources such as printers, system updates, management and traffic monitoring that generate for the production in their daily tasks, because it is good to separate each area by VLAN as the Layer two devices such as the SWITCH allow you to manage multiple ports for each area. This example divides VLAN 10 (RRHH), VLAN 20 (Employees), VLAN 30 (Management), each one assigned to a group of ports, for example, for VLAN 10, all that connect to the ports assigned to that area. To HR, look at the following example:
Vlan 10
name RRHH
VLAN 20
name Empleyoees
VLAN 30
name Management
interface range fa0/1-10
switchport mode access
switchport access vlan 10
interface range fa0/11-15
switchport access vlan 20
interface range fa0/16-22
switchport access vlan 30
interface range fa0/23-24
switchport mode trunk
***** (Generally the ports that are connected between SWITCH are trunk)
****** A trunk port is a port that is assigned to carry traffic for all the VLANs that are accessible by a specific switch, a process known as trunking. Trunk ports mark frames with unique identifying tags – either 802.1Q tags or Inter-Switch Link (ISL) tags – as they move between switches. Therefore, every single frame can be directed to its designated VLAN.
Could you simply consolidate those VLANs in a VLAN?
Of course you can not but you have better control when separating each area.
In your case you must truncate the interfaces that go from swicth to swith and also create in the Router1 subinterfaces so that the routing between VLANs makes sense:
int g0/0
no shutdown
int g0/0.10
encapsulation dot1q 10
ip address x.x.x.x x.x.x.x
int g0/0.20
encapsulation dot1q 20
int g0/0.30
encapsulation dot1q 30
To use a dynamic protocol such as EIGRP, you can do the following for internal VLANs.
router eigrp 1
network IDVLAN10
network IDVLAN20
network IDVLAN30
+++++To manage the clusters better do it from Router1
