Inter vlan
networking11
hi all,
i have 3 blocks of l1-L2 switches, in which first block contains 2 switches of configured 2 vlans vlan 1 in sw11, vlan 1&2 in sw10 of which fast ethernet ports are trunked between Sw10-Sw11 and gigaports of Sw11 and Sw10 are given to L3switch.
in the 2Nd block of L2 switches-3(Sw9 toSw7) is given the vlan 3 and connected to L3Switch via Giga and inturn the 3 switches are cascade or truncated.
in the 3rd block of L2 switches-6(Sw6 toSw1) is given the vlan 2 and connected to L3Switch via Giga and inturn the 6 switches are cascade or truncated.
give me the config
subharojdahal
Your question seems abstract. Well, if you just want to have inter-vlan routing among those 3 vlans than you have and just to have config, then you could follow the following commands.
interface vlan 1
ip address X.X.X.X X.X.X.X
no shut
interface vlan 2
no shut
interface vlan 3
no shut
If you want to configure HSRP then you should have few more command to configure.
subharose
