Interconnecting a 3620 and 1700 Series Router
bentorrales
Hello All,
I have the following situation. I am trying to set up a Cisco Router on my Test Network. However I have not been successful at it. Besides the Configuration That I have provided below I will provide the scenario as of what is happening.
1. When Connecting the 3600 series router with the following configuration 172.18.0.1/16 FastEthernet1/1 to my test Network I am able to ping From FastEthernet0/0 and back from 1/1.
FastEthernet0/0 is configured with the following IP address 192.168.1.1/24 to I can ping any computer that has the gateway 172.18.0.1 on the 1/1 side and I can ping any computer back from 1/1 that has the gateway. However Since I am uplinking to my current test network I am not able to ping or get to other computers unless I put the Gateway of FastEthernet1/1 which the 3600 series.
In my Test Network I have a Catalyst switch 4000 and another Router which links the 1700 Series and the 3600 is there something I am missing?
I am able to ping across the Interfaces but only when they have they respective gateways on the side of 172.18.0.1 I have the 1700 series Router Configure with 172.18.0.2 but I can only ping devices on this segments only when I put the 3600 Series 172.18.0.1 gateway on the computers. Can anyone please let me know what is missing.
Thank you and Best Regards,
Ben Torrales
The Configuration is as Followed
3620#sh ru
Building configuration...24, dst=192.168.1.1, hl=2
Current configuration : 1582 bytes=138
version 12.1
no service single-slot-reload-enable/0, nexthop=192.168.1.1, out=FastEth
service timestamps debug uptime
service timestamps log uptime
-Process= "IP Input", ipl= 0
-Traceback= 60
!D
hostname 362004CE068 60495
!0
logging rate-limit console 10 except errors
enable secret xxx
forward-protocol udp snmp
enable password net
ip subnet-zero
3620#
!6
no ip finger
interface FastEthernet0/0
ip directed-broadcast
speed auto
half-duplex
interface FastEthernet0/1
no ip address
no ip mroute-cache
speed auto
half-duplex
interface BRI1/0
no ip address
no ip mroute-cache
shutdown
isdn switch-type basic-5ess
interface FastEthernet1/0
ip address 172.25.0.9 255.255.0.0
speed auto
half-duplex
no mop enabled
interface FastEthernet1/1
ip address 172.18.0.1 255.255.0.0
ip helper-address 192.168.1.2
speed auto
half-duplex
ip nat inside source list 199 interface FastEthernet1/0 overload
ip classless
ip forward-protocol udp snmp
ip route 0.0.0.0 0.0.0.0 FastEthernet1/0
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip route 0.0.0.0 0.0.0.0 FastEthernet1/1
ip route 63.x.225.x.255.255.0 FastEthernet1/0
no ip http server
access-list 199 permit ip 192.168.0.0 0.0.255.255 any
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
line con 0
transport input none
line aux 0
line vty 0 4
password net
login
end
3620#
globalnettech
Level 5
Level 5
Hello Benjamin,
from what you are saying, your problem occurs when you uplink to your test network, is that right ? Which port on your 3600 router are you using for the uplink ? And what does the config if the 1700 router look like, can you post that as well ?
GNT
Hello GNT,
Thank you so much for your prompt response...
The configuration looks as followed...
FastEthernet0/0
speed auto
half-duplex
FastEthernet1/1
speed auto
half-duplex
Connected to a HUB and HUB uplinked to my test network. Which has another router with 172.18.0.2.
I can ping the gateway and computers with the gateway 172.18.0.1/16 from the 192.168.1.1/24 (0/0) interface; however, I can not ping computers with the gateway 172.18.0.2 From(0/0) I can not even ping From (1/1) to computers with Gateway 172.18.0.2 even though they are both connected to the same hub.
For example:
From 3600 FastEthernet(1/1) connected to HUB 172.18.0.1
From 1700 Ethernet (0/0) connected to HUB 172.18.0.2
Note: The ?HUB? is connected to both routers as mentioned above?
Please refer to my test results?
OK To ping from FastEthernet0/0 192.168.1.1 to the following computer or setting
Computer 172.18.0.100/16
Gateway: 172.18.0.1
UNABLE to ping to 172.18.0.2
Computer 172.18.0.200
Gateway 172.18.0.2
UNABLE to ping from FastEthernet(1/1) 172.18.01
Gateway 172.18.0.2
OK To ping From FastEthernet1/1 172.18.0.1
Computer 192.168.1.100/24
Gateway: 192.168.1.1
Do I have to build the route table? I am not sure what is missing?
Ben Torrales
