Interconnection Between Cisco Nexus 5k
jmp780718
Hi everyone.
I have the next question, If i interconnect two arrangement of Cisco Nexus UCS 5k by an VPC between them, i will have problems with that connection, i will have some impact?; there is any problem with the Vpc domains between them?
Thank you.
Ok, than that should not be an issue.  You connect all 4 5ks full meshed together and put them in one vPC.
I have done it between 5ks and 7ks, but it should work the same way when they are all 5ks.
Reza Sharifi
Not sure exactly what is your question, but are refereeing to 2 sets of 5ks or one set?
Hi Reza.
Is correct i have 2 set of 5Ks and i need to connect between them thru VPC in order to extend vlans.
Thank you.
