Interface on Nexus 5548 inactive, vlan not allowed on peer issue
mike.mccollum1
I've inherited the responsiilities of a pair of Nexus 5548s that are paired together using a port channel link.  I wasn't involved in the setup and I'm just  beginning to get a grasp on the differences between the Nexus and what I am used to.
I am trying to create another Vlan on the Nexus.  I added Vlan 53 and changed a port on a FEX (Cisco 2K) connected to the Nexus.  I also added Vlan 53 to the other Nexus   The interface on the FEX now shows a status of inactive.
I believe the issue is that the port-channel trunk is not passing Vlan 53 through to the other Nexus but I don't know why.
2017 Apr 21 18:00:26 Nexus5548B %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs on Interface Ethernet104/1/8 are being
suspended. (Reason: Vlan is not allowed on Peer-link)
interface port-channel4096
switchport mode trunk
spanning-tree port type network
speed 10000
vpc peer-link
Nexus5548B# show int po4096 trunk
Port Native Status Port
Vlan Channel
Po4096 1 trunking --
Port Vlans Allowed on Trunk
Po4096 1-4094
Port Vlans Err-disabled on Trunk
Po4096 53
Port STP Forwarding
Po4096 1-2,6-7,9-11,17,20,30,33,35,50-51,201-204,206-209,300
Port Vlans in spanning tree forwarding state and not pruned
Port Vlans Forwarding on FabricPath
What I don't understand is how there is no restrictions on the numbers of port vlans allowed on trunk yet port vlan 53 is in err-disabled state.
the command:
show vpc consistency-parameters global
should give you a listing of the allowed Vlans and the peer and local values.Peer and local values need to match, so you have to make sure that the Vlan 53 is listed in both.
Can you post the output of above command ?
Vlan 53 does not seem to be listed in both
Nexus5548B# show vpc consistency-parameters global
Legend:
Type 1 : vPC will be suspended in case of mismatch
Name Type Local Value Peer Value
QoS 2 ([], [], [5], [], [], ([], [], [5], [], [],
Network QoS (MTU) 2 (9216, 0, 9216, 0, 0, (9216, 0, 9216, 0, 0,
0) 0)
Network Qos (Pause) 2 (F, F, T, F, F, F) (F, F, T, F, F, F)
Input Queuing (Bandwidth) 2 (30, 0, 50, 0, 0, 0) (30, 0, 50, 0, 0, 0)
Input Queuing (Absolute 2 (F, F, F, F, F, F) (F, F, F, F, F, F)
Priority)
Output Queuing (Bandwidth) 2 (30, 0, 50, 0, 0, 0) (30, 0, 50, 0, 0, 0)
Output Queuing (Absolute 2 (F, F, F, F, F, F) (F, F, F, F, F, F)
Priority)
STP Mode 1 Rapid-PVST Rapid-PVST
STP Disabled 1 None None
STP MST Region Name 1 "" ""
STP MST Region Revision 1 0 0
STP MST Region Instance to 1
VLAN Mapping
STP Loopguard 1 Disabled Disabled
STP Bridge Assurance 1 Enabled Enabled
STP Port Type, Edge 1 Normal, Disabled, Normal, Disabled,
BPDUFilter, Edge BPDUGuard Disabled Disabled
STP MST Simulate PVST 1 Enabled Enabled
IGMP Snooping Group-Limit 2 4000 4000
Interface-vlan admin up 2 2,6-7,9-11,17,20,30,33 2,6-7,9-11,17,20,30,33
,35,50-51,206,209,300 ,35,50-51,209,300
Interface-vlan routing 2 1-2,6-7,9-11,17,20,30, 1-2,6-7,9-11,17,20,30,
capability 33,35,50-51,206,209,30 33,35,50-51,209,300
Allowed VLANs - 1-2,6-7,9-11,17,20,30, 1-2,6-7,9-11,17,20,30,
33,35,50-51,53,201-204 33,35,50-51,201-204,20
,206-209,300 6-209,300
Local suspended VLANs - 53 -
can you post the port channel configs of both ends ?
Thank you for responding and your time.  Here is the config of all port channels of both ends
Switch A
interface port-channel10
description *** FABRIC A ***
spanning-tree port type edge trunk
speed 10000
vpc 10
interface port-channel20
description *** FABRIC B ***
speed 10000
vpc 20
interface port-channel99
description *** L3 Adjancancy to Switch 2 ***
no switchport
ip address 10.254.254.1/30
ip router eigrp 99
interface port-channel101
switchport mode fex-fabric
fex associate 101
vpc 101
interface port-channel102
shutdown
fex associate 102
vpc 102
interface port-channel103
fex associate 103
vpc 103
interface port-channel104
shutdown
fex associate 104
vpc 104
interface port-channel105
fex associate 105
vpc 105
interface port-channel4095
no switchport
speed 10000
vrf member VPC-HEARTBEAT
ip address 1.1.1.1/30
speed 10000
vpc peer-link
SwitchB
speed 10000
vpc 10
speed 10000
vpc 20
interface port-channel50
description *** TRUNK to FOUNDRY ***
switchport trunk native vlan 2
spanning-tree port type normal
speed 1000
vpc 50
no switchport
ip address 10.254.254.2/30
ip router eigrp 99
shutdown
fex associate 101
vpc 101
fex associate 102
vpc 102
shutdown
fex associate 103
vpc 103
fex associate 104
vpc 104
shutdown
fex associate 105
vpc 105
no switchport
speed 10000
ip address 1.1.1.2/30
speed 10000
vpc peer-link
