Interface problem
makstilcisco
I have strange problem with ports of my Cisco 4507R-E switch. Sometimes is happened when I look in my CUCM 6.1 to see that one or more phones are not registered. I telnet to 4507R switch to see status of port where IP Phone is connected show ip interface brief and the port is UP. Next thing I write following command show mac address-table interface gigabit 1/18 and there no mac address in output. The configuration of the ports is:
interface GigabitEthernet1/18
switchport mode access
switchport voice vlan 50
switchport port-security maximum 2
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
auto qos voip cisco-phone
qos trust device cisco-phone
macro description cisco-phone
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input AutoQos-VoIP-Input-Cos-Policy
service-policy output AutoQos-VoIP-Output-Policy
When I enter commands shutdown and no shutdown on the port interface and after that I enter show mac address-table interface gigabit 1/18 I can see the mac address of devices attached to the port.
VLAN
1 ------ PC
50 -------- IP Phone
and the PC and Phone take IP and everything is OK.
Any idea what can be the problem ?
The IOS is 12.2
bwilmoth
Level 10
Level 10
When a packet gets routed, it carries the source MAC address as that of the physical interface or VLAN interface, which performs the routing rather than the outgoing interface which is in switchport mode.
In order to learn the MAC address of the directly connected interface or port, you can configure the port for native VLAN. When any untagged frames are sent out of this port, the source MAC address associated physical port is learned and added to the MAC address table in the remote device.
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a008011e6b4.shtml#interface_problems
