Interface statistics question
swurmb
This may seem like a simple question, but I am having a hard time finding anything that clearly describes the meaning of "unknown protocol drops" when viewing interface stats.  See the example below (towards the bottom) that was taken from an 1841 router running 12.4T.
FastEthernet0/0 is up, line protocol is up
  Hardware is Gt96k FE, address is xxxxxxxxxxx
  Description: xxxxxxxxxxxxxxxxxxxxx
  Internet address is xxxxxxxxxxxxxxxxxxxxxx
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 5d03h
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 3000 bits/sec, 6 packets/sec
  5 minute output rate 5000 bits/sec, 9 packets/sec
       12106574 packets input, 1221718176 bytes
       Received 992153 broadcasts, 0 runts, 0 giants, 0 throttles
       0 watchdog
       16927799 packets output, 2319562095 bytes, 0 underruns
=>   45936 unknown protocol drops
       0 lost carrier, 0 no carrier
Anyone have an idea?  What causes this?   Thanks for any insights.
Eugene Lau
G'day!
There was an Article written by Xander a while ago which could give you a few ideas
Check it out here:
https://supportforums.cisco.com/docs/DOC-15490
Typically it's a protocol that the routers interface doesn't recognize such as an un-configured protocol.
Eugene.
Thanks, Eugene.    I was suspecting CDP as a culprit and this confirms it.
Appreciate your insights.
-Steve
