Intermittent issue of network service loss
nilaakshverma
We are facing intermittent issue of network service loss, approx. once or twice a week. We experience what appears to be a port flapping issue, which then triggers a series of failovers between switches on the network, which results in users losing internet/WAN access for 5-8 mins in duration and is now having a significant impact. We have changed the network patch cable and port on the primary link, but issue keeps occurring intermittently.
Network Detail:
      ASA
               L3-SW1 --  L3-SW2
         Access Layer
Network design follows 2 tier design with collapsed core and separate access layer.  The ASA 5510 is working as a WAN demarcation device which has an outside & inside zone.
Each L3 switch has a single port which is configured as a trunk link and connected the ASA, from the ASA’s perspective the two links make a port-channel.
(ASA port 1 -> L3Sw1 port 23, ASA port 2 -> L3Sw2 port24
Core switches (Cisco c3560G – hostnames: SH-L3-SW1, SH-L3-SW2) are responsible for fast switching and routing between VLANs.
For redundancy HSRP is configured between ASA and Core switches on a per/VLAN basis with priority of 150 and decrement of 70.
An Ether channel is configured between L3 switches.
Logs for L3Sw1
Oct 22 16:01:12.158 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is down: holding time expired
Oct 22 16:01:53.959 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is up: new adjacency
Oct 22 16:01:54.026 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is down: Interface Goodbye received
Oct 22 16:03:35.076 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is up: new adjacency
Oct 22 16:04:35.357 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is down: holding time expired
Oct 22 16:05:20.270 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is up: new adjacency
Oct 22 16:05:20.279 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is down: Peer goodbye received
Oct 22 16:05:20.279 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is down: Interface Goodbye received
Oct 22 16:07:00.632 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is up: new adjacency
Oct 22 16:07:48.532 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is down: holding time expired
Oct 22 16:08:30.894 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is up: new adjacency
Oct 22 16:08:30.903 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is down: Interface Goodbye received
Oct 22 16:10:10.292 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is up: new adjacency
Logs for L3Sw2
Oct 22 16:06:52.065 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/24, changed state to down
Oct 22 16:06:53.071 BST: %LINK-3-UPDOWN: Interface GigabitEthernet0/24, changed state to down
Oct 22 16:06:55.320 BST: %LINK-3-UPDOWN: Interface GigabitEthernet0/24, changed state to up
Oct 22 16:06:56.326 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/24, changed state to up
Oct 22 16:07:00.638 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is up: new adjacency
Oct 22 16:07:48.537 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is down: holding time expired
Oct 22 16:08:30.900 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is up: new adjacency
Oct 22 16:08:30.900 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is down: Peer goodbye received
Oct 22 16:08:30.900 BST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.10.1.1 (Vlan601) is down: Interface Goodbye received
Oct 22 16:08:54.682 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/24, changed state to down
Oct 22 16:08:55.688 BST: %LINK-3-UPDOWN: Interface GigabitEthernet0/24, changed state to down
Oct 22 16:09:05.109 BST: %LINK-3-UPDOWN: Interface GigabitEthernet0/24, changed state to up
Oct 22 16:09:06.115 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/24, changed state to up
Oct 22 16:09:55.088 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/24, changed state to down
Oct 22 16:09:56.086 BST: %LINK-3-UPDOWN: Interface GigabitEthernet0/24, changed state to down
Oct 22 16:09:58.544 BST: %LINK-3-UPDOWN: Interface GigabitEthernet0/24, changed state to up
Oct 22 16:09:59.551 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/24, changed state to up
Oct 22 16:10:02.629 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/24, changed state to down
Oct 22 16:10:03.636 BST: %LINK-3-UPDOWN: Interface GigabitEthernet0/24, changed state to down
Oct 22 16:10:05.926 BST: %LINK-3-UPDOWN: Interface GigabitEthernet0/24, changed state to up
Any help or advice on how to isolate the cause and resolve this would be very much appreciated- thank you! J
Naman
6 Replies 6
Arjun Sarkar
Hello ,
 Did you check the link status between SW1 and SW2? Do you see any drops? Also please send me the output of " show runn int vlan 601"? Please send me the ouput  of followojgn commands.
show spanning-tree detail  | i ieee|from|exec|occurred
- show ip eigrp events
- show ip eigrp neighbor det
- show int | in line|drops
BEst Regards
Arjukn
Hi Arjukn,
Thanks for your response, I will reply soon will all the required output.
Many Thanks,
Naman
Hi Arjukn,
Hope you are well, As suggested please find the output of commands (attached).
Please feel free to advise further on this issue.
Many Thanks for your help in this troubleshooting.
Naman
arijitghoshal
Hi Nilaaksha,
Bind you switch port and firewall port settings( speed and duplex ). Both end should be same.
Arijit Ghoshal
Spooster IT Services
Hi Arijit,
Thanks for your response, I will bind ports and will make sure that speed  & duplex will be same at both ends.
As it is intermittent issue I will have to wait for a week or two, after that I will confirm back again.
Many Thanks,
Naman
Hi Arijit,
I can confirm that both ends are same.
Kind Regards,
Naman
