cisco 3750 - ip-helper doesn't work
Hello.
        We have a cisco 3750,  ip routing enabled, service dhcp (enabled), 2 vlans: vlan1=LAN, VLAN 202=cisco Phones. I need the phones to get ip addressing with dhcp. Routing is ok, If static address is configured,  two points from each vlan see each other.
Now, I've configured ip helper-address on interface vlan202 so that any device plugged to that subnet can get addressing from a Windows DHCP server on VLAN1. Obviously it doesn't work.
any idea?
Thanks.
harisivaji
Are you able to see DHCP traffic in the device
Can you post the running config
Hari
Here is an excertp of the config.
I cleared things that should have nothing to do with routing and dhcp features.
vtp mode transparent
ip subnet-zero
ip routing
no ip dhcp relay information check
port-channel load-balance src-dst-ip
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 202
name VoIP_GI
interface GigabitEthernet2/0/20
switchport access vlan 202
switchport mode access
speed 100
duplex full
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface Vlan1
ip address 172.16.50.10 255.255.0.0
interface Vlan202
description VoIP_GI
ip address 172.24.202.1 255.255.254.0
ip helper-address 172.16.15.88
ip default-gateway 172.16.1.1
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.1.1
System image file is "flash:c3750-ipbase-mz.122-35.SE5/c3750-ipbase-mz.122-35.SE5.bin"
cisco WS-C3750G-24TS-1U (PowerPC405) processor (revision F0) with 118784K/12280K bytes of memory.
There is a route on the DHCP Server pointing to 172.24.202.10, so that it can reach the vlan.
172.24.202.0    255.255.254.0     172.16.50.10     172.16.15.88
Can you ping the DHCP server from the router?
Hello Everyone. This problem was solved. The key issue was that the scope was created into a "Superscope". In order to get it to work, the scope must be created out.
Thanks for your help. At least, the cisco device config was ok.
Regards.
