Internal Routing Problem
Hi everyone,
I am quite new to vLAN routing so please bare with me! This is the setup I have.
vLAN 1 network 192.168.2.0 with 192.168.2.50 Gateway (firewall amanged by another IT company)
vLAN 4 network 192.168.4.0 with 192.168.4.250 as Gateway which is a UC560 (its vLAN IP is .2.250)
vLAN 100 10.1.1.0 network and UC being the gateway as well.
I have asked the other IT company to add static routes to point 192.168.4.0 network to UC560 ip of 192.168.2.250 and 10.1.1.0 to point to gateway of 192.168.2.250 as well. They have told me that the first route has been added but I am unable to ping any vLAN 4 devices from vLAN 2 and I am having some communication problems between vLAN 4 devices as well. Oh, and also, vLAN 4 cannot access the internet.
I have add vLAN 4 to UC560 and to all the uplinks and relevant ports on the switches which are ESW-500 series. Any ideas, am I missing something?
Many thanks
13 Replies 13
Latchum Naidu
Hi Dmitry,
It looks you have configure those three vlans (VLAN1, VLAN4 AND VLAN100) in different individual devices.
If you want those three VLANS needs to be communication there must be a static router in each device.
And those three devices (on which you have configured each vlan) needs to be TCP communication firstly.
Say for example your Firewall, UC560 and another device firstly communicate each other means they must be have one interface in same network.
Then you can point the defined Vlan network traffic with static route pointing to the interface through which the Firewall is able to communicate UC560 for example.
Please rate all the helpfull posts.
Naidu.
The UC has all the 3 vlans set up inside of it and there is a gateway on UC of 192.168.2.50 which is the firewall. It's the default gateway on vlan 1 network.
UC can communicate with the firewall fine, the problem I am having is a server on 192.168.4.251 talking to a device on 192.168.4.1 IP address. These devices are both on the same switch and have a default gateway of 4.250.
I can ping 192.168.4.1 from UC560 but I cannot ping 192.168.4.251.
I have also added a static route of 192.168.4.0 255.255.255.0 gateway 192.168.2.250 on 192.168.4.251 windows server, this allowed me to start pinging the vlan 4 network.
get the following outputs
sh ip route
sh int vlan
get the sh run from the switch and the UC .
Shine
From the UC
Gateway of last resort is 192.168.2.50 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 192.168.2.50
      10.0.0.0/8 is variably subnetted, 5 subnets, 3 masks
C        10.1.1.0/24 is directly connected, Vlan100
L        10.1.1.1/32 is directly connected, Vlan100
C        10.1.10.0/30 is directly connected, Vlan90
S        10.1.10.1/32 is directly connected, Vlan90
L        10.1.10.2/32 is directly connected, Vlan90
      192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.2.0/24 is directly connected, Vlan1
L        192.168.2.250/32 is directly connected, Vlan1
      192.168.4.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.4.0/24 is directly connected, Vlan4
L        192.168.4.250/32 is directly connected, Vlan4
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is 588d.093b.4f62 (bia 588d.093b.4f62)
  Description: $FW_INSIDE$
  Internet address is 192.168.2.250/24
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive not supported
  Last input 00:00:00, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 3000 bits/sec, 3 packets/sec
  5 minute output rate 3000 bits/sec, 3 packets/sec
     990104 packets input, 145182027 bytes, 0 no buffer
     Received 364422 broadcasts (649 IP multicasts)
     1199493 packets output, 169793606 bytes, 0 underruns
     0 output errors, 1 interface resets
     98898 unknown protocol drops
Vlan4 is up, line protocol is up
  Description: wireless$FW_INSIDE$
  Internet address is 192.168.4.250/24
  5 minute input rate 2000 bits/sec, 2 packets/sec
     1201100 packets input, 157197294 bytes, 0 no buffer
     Received 238452 broadcasts (7 IP multicasts)
     382629 packets output, 81876896 bytes, 0 underruns
     4557 unknown protocol drops
Vlan100 is up, line protocol is up
  Internet address is 10.1.1.1/24
  5 minute input rate 1000 bits/sec, 2 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
     1165656 packets input, 75015139 bytes, 0 no buffer
     Received 52248 broadcasts (0 IP multicasts)
     1566987 packets output, 129381141 bytes, 0 underruns
     126 unknown protocol drops
I cannot get access to the switches at the moment as I am waiting for the other IT company to provide me with VPN to them.
This seems to be your topology.
VLAN1, VLAN4, VLAN 100 -----> UC -----> FW -----> Internet
Well as long as your clients have the appropriate gateway configured for their VLANs, they should go to the UC as their default gateway, so all remote destination packets should go to the UC. From there you have a static route configured for 192.168.2.50.
What vlans are currently having trouble accessing the internet?
I did notice that VLAN1 has a default default of 192.168.2.50 per your first post. If VLAN1 wants to communicate with anything outside of its local network it will have to go to the FW first, since that's it's default gateway, the FW will then have to have routes configured to go to the whatever local subnet you want to communicate with. So, for VLAN2 to communicate with VLAN4, it will have to go from VLAN2 -> FW -> back to UC -> Then to client. It looks like inefficient routing. The packet will have to go out the interface it came in on the FW to get back to its destination. Depending on how you have the rest of your entire network setup, you may want to set the default gateway for VLAN1, to the UC, then the UC will have a default static route to 192.168.2.50, which is the FW.
When you're own VLAN4, do a traceroute to 8.8.8.8 and post the results if you don't mind.
Hi John,
Devices on vlan 1 have default gateway of 192.168.2.50 (firewall) and devices on vlan 4 have default gateway of 192.168.4.250 (UC). Is this wrong then?
VLAN 4 devices are the ones which are struggling to get internet access. I believe the static route for 192.168.4.0/24 to 192.168.2.250 has been deleted from the firewall (192.168.2.50).
Anyway this is the tracert from the UC which has access to the internet.
Tracing the route to google-public-dns-a.google.com (8.8.8.8)
  1 192.168.2.50 0 msec 0 msec 4 msec
  2 host81-142-246-129.in-addr.btopenworld.com (81.142.246.129) 0 msec 0 msec 4                               msec
  3 host81-134-96-1.in-addr.btopenworld.com (81.134.96.1) 12 msec 16 msec 12 mse                              c
  4 213.120.182.141 12 msec 12 msec 12 msec
  5 213.120.161.82 12 msec 12 msec 12 msec
  6 217.41.222.78 12 msec 12 msec 12 msec
  7 217.41.222.178 12 msec 12 msec 12 msec
  8 acc1-10gige-0-5-0-4.bm.21cn-ipp.bt.net (109.159.248.96) 12 msec
    acc1-10gige-0-1-0-6.bm.21cn-ipp.bt.net (109.159.248.94) 16 msec
    acc1-10gige-0-0-0-4.bm.21cn-ipp.bt.net (109.159.248.66) 12 msec
  9 core2-te-0-13-0-4.ilford.ukcore.bt.net (109.159.248.10) 20 msec
    core2-te-0-2-5-0.ilford.ukcore.bt.net (109.159.248.2) 20 msec
    core1-te0-13-0-4.ealing.ukcore.bt.net (109.159.248.8) 24 msec
- It's not really wrong, you just need routes back your local subnets from 192.168.2.50(which is your FW). But from a network design perspective, For VLAN1 to communicate with any of the inside networks, it will go to the FW first, since it's default gateway is 192.168.2.50, and then it will have to have routes on the FW back to the internal subnets. So, in theory it will work just fine it just may not be the best network design scenario. If you configured VLAN1 default gateway to be on the UC, then it would already have static routes to all the internal subnets, and then from there, if it wants to communicate with the internet, it
will go to the FW. THe traffic flow will be like VLAN1 --> UC(local routes) --> FW --> Internet.
If that is the case then, VLAN4 will be able to send packets out to the internet, but when it comes back to the firewall, the firewall will not have a route to 192.168.4.0, so it will not be able to reply to VLAN4. Was that traceroute done from a client PC on VLAN4?
I had TeamViewer access to the server on 192.168.4.251 IP and as soon as I took the default gateway off from the second LAN adaptor which was connecting to only vlan1, it threw me off it. School boy error!
Once the IT department gets me VPN access I should be able to get back and do those traceroutes for you.
Also, I should be able to access the 192.168.4.251 from the UC shouldn't i? As they are on the same vlan and 192.168.4.251 has gateway of the UC. I am getting no ping reply from .4.251
Well if you are trying to ping from the UC, I believe it is using the managment vlan to ping, so it would be VLAN2 to VLAN4, which is one of the issues yo uare having, so that may be why it's not working.
Try to ping 4.254 with a source of another vlan interface on the UC and see what happends.
Getting no reply from 192.168.4.251 at all. I do get one from 192.168.4.1. Perhaps the network settings have been set up wrong or I forgot to add the default Gateway!
If they're on the same network they will communicate via ARP.  Could be a L2 misconfiguration some where.
What I am going to do is get a cable from one of the switches, set it to access on vlan 4 and connect to the firewall. We will then use the firewall as the default gateway instead on 192.168.4.50. This should do the trick!
