Bookmark
Subscribe
5279
Internet dropping with 861 router and DPC3010 cable modem
stevenbarnes
Hi all,
I am having an issue with my network that has me perplexed.
I have a DPC3010 cable modem (Charter internet).
I previously had it connected to a Linksys WRT54GL with DD-WRT installed and that was working ok except that I had to reboot it 2-3 times per week.
I replaced it with a Cisco 861 (non-wireless) router and it worked ok for a few hours then it started dropping the internet connection (it goes up and down constantly)
If I switch back to the Linksys everything works fine again
I am using the same cables in either case so I know it's not a cabling issue
I upgraded the firmware to c860-universalk9-mz.151-4.M3.bin, but it made no difference
I was starting to suspect a problem with the physical ports on the router, but I decided to try connecting the 861 behind the Linksys and turns out it works fine in that setup.
So to recap...
If I connect the 861 directly to the modem my internet connection bounces up and down
If I connect the Linksys directly to the modem my internet connection is fine
If I connect the Linksys directly to the modem and the 861 to the Linksys everything works fine (my PC is connected to the fe0 port of the 861)
Are the 861 and the modem simply incompatible or is it a configuration issue?
I have attached my 861 config to this thread.
Any help you can provide would be greatly appreciated
Thanks in advance
Steven
Hi Steven,
take a look at this:
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_dns1.html#wp1013357
it is possible that the option none in the WAN interface is not the one you want:
interface FastEthernet4
description $ETH-WAN$
ip dhcp client update dns server none
ip ddns update hostname myusername.dyndns.org
ip ddns update ccp_ddns1
ip address dhcp client-id FastEthernet4
ip nat outside
ip virtual-reassembly
duplex auto
However, i would suggest to buffer more info in order to understand what is happening. You can type:
conf t
logging buff 16384 deb
end
wr
Of course a sho logg would show the info and debugging events could be another way to catch what is happening.
Alessio
Thanks Alessio... I am away right now, but I will give your suggestion a try when I return and let you know what happens (it will probably be this evening)
Sorry it took me so long to get back with you.
It ended up being a problem with my default route
I had... ip route 0.0.0.0 0.0.0.0 FastEthernet4 permanent
and I needed to have... ip route 0.0.0.0 0.0.0.0
thanks
