Internet speed issue
iftikhar.haidar
Visitor
Dear Sir,
Kindly i need the help . i have 200 mbps internet speed from ISP. i am getting the same speed once i connect to the sophos firwall but one i connect that port to my cisco switch WS-C3850-24P
series than i am getting the 100 mbps speed. kindly anyone have the solution that what is the exact problem.
Your quick response will be highly appreciated.
Thanks.
18 Replies 18
Leo Laohoo
@iftikhar.haidar wrote:
but one i connect that port to my cisco switch WS-C3850-24P series than i am getting the 100 mbps speed
Maybe the switch has negotiated the port speed to 100 Mbps.
The ports are gigabits.
Post the complete output to the command "sh interface <PORTS>".
I want to see the output of the WAN port as well as the port used to perform the speed tests.
Dear Leo laohoo,
Please check the below Result.
Thanks.
Georg Pauwen
post the output of:
show interfaces x
where 'x' is the interface of your 3850 that has the speed issue...
Joseph W. Doherty
Possibly like Georg and Leo, since you describe obtaining 100 Mbps, I too would look for a port or ports running at 100.  Notice my mention of "port or ports".  I.e. you need to check all ports from device performing speed test to/from ISP.
Martin L
Besides port speed, check your cable. Make sure it is CAT 5e or better yet Cat6 as all 8 pair of wires must be active to move at 1 Gig speed of data.
Regards, ML
**Please Rate All Helpful Responses **
Dear Martin,
The same cable when I am connecting to my laptop is getting 200 mbps.
Thanks.
Gaurav  Kansal
Level 5
Level 5
Dear Iftkhar,
Please check your switch port speed. Please set speed 1000.
Goodluck..
yes the speed is 1000 . when i connect that port in my laptop i am getting 200 mbps speed.
there is no issue in port.
Thanks..
Dear Sir,
check the attachment.
Thanks..
What "attachment"?
johnlloyd_13
Level 11
Level 11
hi,
is the ISP hand off an ethernet/RJ45 cable?
try to bypass your sophos FW by connecting directly a laptop to ISP cable, manually set public IP and perform an FTP or iperf test.
Dear Sir,
I checked the speed from the ISP modem directly 200 mbps and after
connecting the firewall i am getting the same speed 200 mbps.
Thanks.
