InterVLAN access control
Intelligroup_2
Community Member
I have a couple of VLANs on my Cisco 4507.
These are the Vlans
10.10.1.X/24 -- management
10.10.2.X/24 -- User vlan
10.10.3.X/24 -- Server vlan
I don’t want 10.10.2.x and 10.10.3.x to access Management network.
But management network (10.10.1.x) should be able to access these two networks.
I have tried access lists but it doesn’t work. If I stop access, it stops both ways. But I want the Management network to be able to access the other networks.
Kindly suggest.
8 Replies 8
Ganesh Hariharan
Check out the following link for Vlan ACl hope this will help you out to resolve your problem
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/secure.html#wp1069375
Ganesh.H
Intelligroup_2
Community Member
Can you kindly provide the exact statements to achive this.
Which way i have to implement the access list (in / out) and which Vlan is this to be put on.
Thanks.
A VLAN map works like a route map,to configure VLAN maps to control IP traffic,first configure the VLAN map and tehn assign a sequence number to the map,VLAN maps are excuted from the lowest instance to the highest.use the global configuration command vlan access-map map_name sequence number.
It work genrally  in direction when applied into a VLAN
Hope this solved your query and help to restric traffic in your vlan
Ganesh.H
sourabh1000_2
Level 3
Level 3
hi,
as per your requirement, you can use pvlan configuration where your can keep your management vlan in primary vlans and sever, user vlans will be in isolated vlans
hope to get some clues from this.
Thanks and Regards,
sourabh
I have tried Vlan maps... still doesn’t work.
Extended IP access list test-acl
     10 permit ip 10.10.2.0 0.0.0.255 10.10.1.0 0.0.0.255
vlan access-map test-map 10
  action drop
  match ip address test-acl
vlan access-map test-map 20
  action forward
I am not able to ping the server vlan form user vlan. Able to ping other subnets.
But  I am also not able to ping user Vlan from the management VLan, which still doesn’t solve my problem.
venkat
Try this configuration as per your setup
vlan access-map allow_ip 10
match ip address deny_to_mangement_lan
action drop
vlan access-map allow_ip 20
match ip address mangement_lan_to_all
action forward
exit
ip access-list extended deny_to_mangement_lan
permit ip 10.10.3.0 0.0.0.255 10.10.1.0 0.0.0.255
exit
ip access-list extended mangement_lan_to_all
permit ip 10.10.1.0 0.0.0.255 any
exit
vlan filter allow_ip vlan-list "management vlan number"
Hope this helps you out
Ganesh.H
Is it to be applied on the Mgmt VLAN?
If so i have to wait till the week end to be able to test this as it will inpact the production.
Yes you need to apply on Management vlan only try the configuration and share your feedback by end of the week.
Ganesh.H
