intervlan Communication help
srikanth ath
Level 4
Level 4
HI all experts
I was really fed up with this.gave a lot of try on using extended name ACL and Extended Numbered ACL...
HOpe u help me out with this
-ONly two IPs(10.10.30.2(vlan 101)  and 10.10.14.2(vlan 99)) should communite to all IPs of  vlan 50 and rest all should be denied.
(((*****here is how i want
10.10.30.2 ---------permit--------10.10.18.0/24
10.10.14.2--------permit---------10.10.18.0/24
deny ip any any (rest all should be denied)
HOw to accomplish this/
Switch(config)#do sh ip route
     10.0.0.0/24 is subnetted, 3 subnets
C       10.10.14.0 is directly connected, Vlan99
C       10.10.18.0 is directly connected, Vlan50
C       10.10.30.0 is directly connected, Vlan101
Switch(config)#
  <cr>
Switch#sh vlan bri
Switch#sh vlan brief
VLAN Name                             Status    Ports
1    default                          active    Fa0/2, Fa0/3, Fa0/4, Fa0/5
                                                Fa0/6, Fa0/7, Fa0/8, Fa0/9
                                                Fa0/13, Fa0/14, Fa0/19, Fa0/21
                                                Fa0/22, Fa0/23, Gig0/1, Gig0/2
50   isolatedservers                  active    Fa0/20
99   branch                           active    Fa0/10, Fa0/11, Fa0/12
101  wifi                             active    Fa0/15, Fa0/16, Fa0/17, Fa0/18
where to implicit the acccess-list here & how...at interface vlan 50 ?
Thanks in advance
sreek
power.srvi
hi,
try this
For the 10.10.30.2---->10.10.18.0/24:
ip access-list extended vlan-101
permit ip host 10.10.30.2 10.10.18.0 0.0.0.255
deny ip 10.10.30.0 0.0.0.255 10.10.18.0 0.0.0.255
permit ip any any ( this  line if you want to let the rest of users go to internet )
interface vlan 101
ip acces-group vlan-101 in
For the 10.10.14.12---->10.10.18.0/24:
ip access-list extended vlan-99
permit ip host 10.10.14.12 10.10.18.0 0.0.0.255
deny ip 10.10.14.0 0.0.0.255 10.10.18.0 0.0.0.255
interface vlan 99
ip acces-group vlan-99 in
Hey thanks a lot SRVI.
i was trying to give an access list under vlan 50 ----to block all vlan ips except two (10.10.30.2 & 10.10.14.2) where in i failed .........
and one more in this way we can only block  1 way traffic is ..
1. where should i aappply access-lists..... If i want vlan 50 shouldnt communicate to other vlans except the two  10.10.30.2 (vlan 101)& 10.10.14.2 (vlan 99) ???
2/ and can you say what exactly happenenning here if give ip access-group vlan-101 out ? though i need acces-group in...just to understand
interface vlan 101
ip acces-group vlan-101 out ?
THanks in advance
hi
you should applu your access list on the vlan interfaces :
exemple
conf t
your-switch(config)# inerface vlan 101
your-switch(config-if)#  ip acces-group vlan-101 in     (note: the vlan-101  after the command ip acces group is the name of the acl
if you want vlan 50 stop to communicate with others exept  10.10.30.2 (vlan 101)& 10.10.14.2 (vlan 99)
ip access-list extended vlan-50
permit ip  10.10.18.0 0.0.0.0 host 10.10.30.2
permit ip  10.10.18.0 0.0.0.0 host 10.10.14.2
to apply to an interface
ip interface vlan 50
ip access-group vlan-50 in
about the in and out,  if you specify ip access-group xxxx in, it will be aplly the access list to a traffic coming from host to the vlan interface and then nedd to be internally routed or go outside
if you specify out it will be applied on the traffic leaving the interface aigainst the acces list
regards
Hi all
i have ca t3750.. lan base image (L3 switch)
by moving 10.10.18.0/24  (isolated servers)to a ***private vlan*** ..can i allow few IPs  of other vlan to communicate with the 10.10.18.0/24
10.10.30.2< <<<<---------permit-------->>>10.10.18.0/24(private vlan)
10.10.14.2<<<--------permit--------->>>>10.10.18.0/24(private vlan)
Thanks and regards
srikanth
