intervlan connection problem.
franzcvel
Good Day Everyone,
I'm a currently creating an intervlan topology.
As of now I'm established tha VLAN and IP, applied trunking and vtp as well as used STP.
However when I run it, only PC 1 (vlan 1 ip 192.168.1.100) managed to ping my 2 routers and it cannot ping the other computers, likewise the rest (PC 2 ~ 4) cannot ping PC 1 or the 2 routers.
Can someone please check what did I do wrong?
I'm kinda new to this and I already spend hours to make this system, I really don't want to start from scratch again =(
Any information to help me managed to ping all the pcs and routers is very much appreciated.
Please and Thank You =)
s.lachica
Hi Francis,
I have seen your packet-tracer file. The reason why you cannot connect PC1 (VLAN 1 ) to the rest of the other vlans is because you are lacking configuration on your Fa0/1 in Multilayer SW2.
configure terminal
interface Fa0/1
  switchport mode trunk
end
Once you do this, wait for stp to converge and for arp to work for a while, and you can now ping between VLAN 1 and 2.
For the other VLANs, 3 and 4, you need to configure also Multilayer switch 3 like this on interface Fa0/1.
Please don't forget to rate my reply.
Sonny
CCIE (R&S) #27666 CCSI HP MASE
s.lachica
Hi Francis,
configure terminal
interface Fa0/1
end
Sonny
Thanks alot it worked ^_^
