I need to connect an ASA5505 to a 881 using a Vlan
CSCO12392384
I am trying to connect two different networks together. The networks live simultaneously in a network closet, so I do not want to Connect then with a VPN.
Both networks have their own ISPs and should remain that way.
One network uses an ASA5505 base services model, and the other a Cisco 881.
I need to connect the two so that servers on either network can communicate.
I think it should be as simple as configuring an SVI on the 881 to the existing Vlan subnet on the ASA.
I am new at posting, and am planning to try this over the weekend. So I do not have configs yet. I am mainly trying to figure out if it is possible??
s.lachica
Hi  Jesse,
If I am in your position, what i will do is something like this:
First, if they are directly-connected, then
ASA5505[L3-interface]-------------------[L3-interface]Cisco881
or,
If they are connected via a L2 switch,
ASA5505[L3-interface]----------[L2}Switch[L2]---------[L3-interface]Cisco881
Configure one interface of the ASA and the interface of the 881 router with /30 point-to-point ip address.
Then static routes can be configured on both sides that is redistributed to routing protocols can be configured.
Example:
ASA5505:
configure terminal
interface Gx/y
description [To Cisco 881]
nameif
security-level
ip address
route ()
router ospf x
redistribute static subnets
or,
router eigrp x
redistribute static metric 1 1 1 1 1
CCIE (R&S) #27666 CCSI HP MASE
