Intervlan routing and NAT
zaidiatifs
hi i am trying to have the vlans communicate with each other using router on a stick , i have attached the packet tracer file for the same .
i have configured subinterfaces on the router and still the vlans are not able to communicate with each other , please advise and help me .
thanks .
8 Replies 8
Bilal Nawaz
Hello Atif,
There are a couple of things that were missing and  perhaps configured wrong... I'll try to explain these to help you  understand what is required. You can find attached my version with  complete connectivity.
The gateway on the laptop in vlan 10 was wrong, so i corrected this.
You  had VTP set up which is good, however the vlans were not created on the  VTP Server. So I created the vlans on the VTP server and subsequently  they got created on the clients.
Then I made sure that I put the  Laptops in the correct vlan as access ports. You just had 'switchport  mode access' - this by default puts everything in vlan 1.
I also made sure that the trunks were functional between the switches and were carying the correct vlans.
'switchport mode trunk'
After I had done these steps, I verified that there was LAN connectivity and also intervlan routing.
Next is to see what the enterprise core router is  doing. It does not have any routes, nor does it have a frame-relay  encapsulation set on the outgoing interface to the internet, we need to  set a default route to the internet too right?
First we get the frame-relay working
Core router
interface Serial3/0
ip address 65.10.1.1 255.255.255.252
encapsulation frame-relay
Remote router
interface Serial2/0
ip address 65.10.1.2 255.255.255.252
I had to create a DLCI on the service provider cloud to make the frame-relay mapping to work. I used 101 mapping for both of them.
However the enterprise core does not have routes to get back to vlan 10,20,30,40,50 and 60.
I  see that you have tried to enable RIP v2 with the Enterprise core  router, and i have completed this and the routes are advertised, I also  generated the default route from the Core and advertised it to Router 1  and the branch router.
i did this with the 'default-information originate' command.
Core router
router rip
version 2
network 10.0.0.0
network 65.0.0.0
no auto-summary
Now the core has routes to get to the intervlan subnets and also 172 network.
core#show ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is not set
     10.0.0.0/30 is subnetted, 1 subnets
C       10.10.1.32 is directly connected, Serial2/0
     20.0.0.0/24 is subnetted, 1 subnets
R       20.10.1.0 [120/1] via 10.10.1.33, 00:00:27, Serial2/0
     30.0.0.0/24 is subnetted, 1 subnets
R       30.10.1.0 [120/1] via 10.10.1.33, 00:00:27, Serial2/0
     40.0.0.0/24 is subnetted, 1 subnets
R       40.10.1.0 [120/1] via 10.10.1.33, 00:00:27, Serial2/0
     50.0.0.0/24 is subnetted, 1 subnets
R       50.10.1.0 [120/1] via 10.10.1.33, 00:00:27, Serial2/0
     60.0.0.0/24 is subnetted, 1 subnets
R       60.10.1.0 [120/1] via 10.10.1.33, 00:00:27, Serial2/0
     65.0.0.0/30 is subnetted, 1 subnets
C       65.10.1.0 is directly connected, Serial3/0
     100.0.0.0/24 is subnetted, 1 subnets
R       100.10.1.0 [120/1] via 10.10.1.33, 00:00:27, Serial2/0
     172.16.0.0/28 is subnetted, 1 subnets
R       172.16.1.0 [120/1] via 65.10.1.2, 00:00:04, Serial3/0
core#
Note that there was no need for NAT.
Hope this helps, please ask if you have any questions.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hello All
Just like to mention as for the serial interfaces not having Fame relay encapsulation, just because it not showing the encapsulation doesn't mean it not using any, like HDLC.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Hello Paul,
I would disagree in that (we leave it as default - no encap specified) But you are correct - the default here is HDLC, in this case you had to enable the encapsulation type for the interface to transition to an 'UP' state and was infact necessary - it may be using HDLC by default but in this case it wouldn't work with this default.
In PT the cloud is a cloud with FR capabilities - this is the only thing stated here. So one should assume the encapsulation to be frame-relay.
core(config)#int s3/0
core(config-if)#no encapsulation
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial3/0, changed state to down
core(config-if)#
core(config-if)#encapsulation frame-relay
core(config-if)#
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial3/0, changed state to up
core(config-if)#
With encap
core#show int se3/0
Serial3/0 is up, line protocol is up (connected)
  Hardware is HD64570
  Internet address is 65.10.1.1/30
  MTU 1500 bytes, BW 128 Kbit, DLY 20000 usec,
  Encapsulation Frame Relay, loopback not set, keepalive set (10 sec)
  LMI enq sent  2, LMI stat recvd 2, LMI upd recvd 0, DTE LMI up
  LMI enq recvd 0, LMI stat sent  0, LMI upd sent  0
LMI DLCI 1023  LMI type is CISCO  frame relay DTE
  Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0
  Last input never, output never, output hang never
  Input queue: 0/75/0 (size/max/drops); Total output drops: 0
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 96 kilobits/sec
  5 minute input rate 6 bits/sec, 0 packets/sec
  5 minute output rate 25 bits/sec, 0 packets/sec
     75 packets input, 3900 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     74 packets output, 14208 bytes, 0 underruns
     0 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
With default hdlc
core#show int se3/0
Serial3/0 is up, line protocol is down (disabled)
  Hardware is HD64570
Encapsulation HDLC, loopback not set, keepalive set (10 sec)
  5 minute input rate 11 bits/sec, 0 packets/sec
  5 minute output rate 35 bits/sec, 0 packets/sec
Hello bilal
i am not saying his issue doesnt require FR
i cannot see the packet tracer so cannot comment on that - however hdlc is a viable encasulation and if this is a back to back connection then FR isnt applicable
All that is requied is Just to disable keepalives and clock rate in the dce
Res
Paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
Okay, i see what you mean now
Are there any pro's or con's with either, just out of interest?
Hi Bilal,
either what ?
Alain
Hello Alain,
I mean between HDLC / or default encapsulations vs Frame Relay in this type of legacy 'cloud environment'
Are there any proper benefits - like performance etc...
In Atif's case he was using a frame-relay cloud so encapsulation was necessary,
For his other links, default was used with no encapsulation set. Just to paint the picture here's a screenshot
Hello
One is using the Fr cloud the other isn't
no lmis or static mappings!
res
paul
Kind Regards
Paul
