02-23-2012 01:57 PM - edited 03-07-2019 05:08 AM
Hola a todos a ver si me pueden colaborar, tengo un sw con la siguiente configuracion.
version 12.2
no service pad
hostname cisco
boot-start-marker
boot-end-marker
enable secret 5 $1$tDRV$ZukjERH2x/F/HH194E7ty1
enable password admin
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.3.1 192.168.3.40
ip dhcp excluded-address 192.168.10.1 192.168.10.20
ip dhcp excluded-address 192.168.20.1 192.168.20.20
ip dhcp excluded-address 192.168.30.1 192.168.30.20
ip dhcp excluded-address 192.168.40.1 192.168.40.20
ip dhcp pool vlan3
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
dns-server 192.168.2.254
ip dhcp pool vlan10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip dhcp pool vlan20
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
ip dhcp pool vlan30
network 192.168.30.0 255.255.255.0
default-router 192.168.30.1
ip dhcp pool vlan40
network 192.168.40.0 255.255.255.0
default-router 192.168.40.1
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1
switchport access vlan 3
switchport mode access
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
switchport access vlan 10
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
switchport access vlan 20
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
switchport access vlan 30
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
switchport access vlan 40
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
no switchport
ip address 192.168.2.39 255.255.255.0
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
no ip address
shutdown
interface Vlan3
ip address 192.168.3.1 255.255.255.0
interface Vlan10
ip address 192.168.10.1 255.255.255.0
interface Vlan20
ip address 192.168.20.1 255.255.255.0
interface Vlan30
ip address 192.168.30.1 255.255.255.0
interface Vlan40
ip address 192.168.40.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.2.254
ip http server
control-plane
line con 0
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
end
Todo me funciona perfecto pero los equipos de mis vlan no pueden navegar, ni pueden hacer ping al 192.168.2.254 que es la ip de mi ruta estatica.
que estoy haciendo mal
Gracias
02-23-2012 02:35 PM
This device (192.168.2.254) needs a route back to 192.168.3.0/24, 192.168.10.0/24, 192.168.20.0/24, 192.168.30.0/24 and 192.168.40.0/24 pointing to 192.168.2.39 as the gateway.
02-23-2012 03:40 PM
hi, The divice 192.168.2.254 is my firewall and my dns, this is the config:
ip:192.168.2.254
netmask: 255.255.255.0
Gateway: 192.168.2.254
DNS: 192.168.2.254
in this moment this is the gateway of my lan, how can i do to do when you say: a route back
02-24-2012 01:13 PM
The FW is configured with a gateway to itself?
ip:192.168.2.254
How the FW knows to send the packets towards the internet?
What kind of FW are you running (manufacturer)?
You will have to contact its vendor for instruction on how to configure routing in it.
Your FW needs to know about the subnets residing behind your 3560 switch.
Edison
02-24-2012 01:18 PM
My FW is a host linux with shorewall, dansguardian, squid, samba.
etho: WAN
eth1: 192.168.2.254/24 = LAN in 192.168.2.0
eth2: DMZ
Milton
PD: this is how i make de config:
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008019e74e.shtml
