InterVLAN Routing
pischta
I tried out the following document:
https://www.cisco.com/c/en/us/support/docs/lan-switching/inter-vlan-routing/41860-howto-L3-intervlanrouting.html
I can ping computers in same vlans, and in other vlans. I can ping 200.1.1.1, but cannot ping 200.1.1.2 from client computers. Some outputs from the switch (3560):
#show ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is 200.1.1.2 to network 0.0.0.0
10.0.0.0/24 is subnetted, 3 subnets
C 10.1.2.0 is directly connected, Vlan2
C 10.1.3.0 is directly connected, Vlan3
C 10.1.10.0 is directly connected, Vlan10
C 200.1.1.0/24 is directly connected, FastEthernet0/1
S* 0.0.0.0/0 [1/0] via 200.1.1.2
#show ip interface brief
FastEthernet0/1 200.1.1.1 YES manual up up
FastEthernet0/2 unassigned YES NVRAM up up
FastEthernet0/3 unassigned YES NVRAM up up
FastEthernet0/4 unassigned YES NVRAM down down
FastEthernet0/5 unassigned YES NVRAM up up
FastEthernet0/6 unassigned YES NVRAM up up
FastEthernet0/7 unassigned YES NVRAM down down
FastEthernet0/8 unassigned YES NVRAM down down
FastEthernet0/9 unassigned YES NVRAM down down
FastEthernet0/10 unassigned YES NVRAM up up
FastEthernet0/11 unassigned YES NVRAM up up
FastEthernet0/12 unassigned YES NVRAM down down
GigabitEthernet0/2 unassigned YES NVRAM down down
Vlan1 unassigned YES NVRAM administratively down down
Vlan2 10.1.2.1 YES manual up up
Vlan3 10.1.3.1 YES manual up up
Vlan10 10.1.10.1 YES manual up up
Thank you.
Seb Rupik
Hi there,
What device is 200.1.1.2 ?
Does it know how to reach VLANS 2, 3 and 10 ?
I suspect you need to add routes those VLANs onto the 200.1.1.2 gateway:
ip route 10.1.2.0 255.255.255.0 200.1.1.1
ip route 10.1.3.0 255.255.255.0 200.1.1.1
ip route 10.1.10.0 255.255.255.0 200.1.1.1
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
Thank you for your answer, when I set the routes you recommended, it worked. 200.1.1.2 device is a 1841 router.
