INTERVLAN Routing
nsamaniego
Frequent Visitor
Frequent Visitor
Hi There,
I have a question regarding inter-vlan routing. I am currently studying this using GNS3.
Please see the attached image for the simple topology.
The ISP is setup to use NAT and Internet is working from DSW-2.
ISP:
ip nat inside source list 1 interface Ethernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip address 192.168.1.202 255.255.255.0
ip nat outside
ip virtual-reassembly in
interface Ethernet0/1
ip address 192.168.5.2 255.255.255.0
ip nat inside
DSW-2# show ip route
S* 0.0.0.0/0 [1/0] via 192.168.5.2
192.168.5.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.5.0/24 is directly connected, Ethernet1/1
L 192.168.5.2/32 is directly connected, Ethernet1/1
192.168.90.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.90.0/24 is directly connected, Vlan90
L 192.168.90.252/32 is directly connected, Vlan90
C 192.168.20.0/24 is directly connected, Vlan20
L 192.168.20.252/32 is directly connected, Vlan20
DSW2#sh ip int brief
Ethernet1/1 192.168.5.1 YES manual up up
Vlan2 192.168.20.252 YES manual up up
Vlan10 192.168.90.252 YES manual up up
The problem is, none from VLAN 2 and VLAN 10 is not connecting to the internet.
Hosts on VLAN 2 & VLAN 10 are able to ping each other using DSW2's VLAN IP Address as default gateway.
IP Routing is enabled in DSW2, as well.
How can I get the host from VLAN2 & VLAN 10 to access the internet? Am I missing some additional configuration here or maybe it could be just the GNS3 issue here?
luis_cordova
Hi @nsamaniego
In the ISP router you must configure a route for the vlan networks.
Either through static routes or dynamic routing.
That way, the packets can reach the vlan on their way back.
luis_cordova
Hi @nsamaniego
Yeah. You are correct, The ISP router doesn't know how to get back to the internal networks of DSW2.
Thank you so much!
Reza Sharifi
You are missing an access list
access-list 10 permit 192.168.5.0 0.0.0.255
I have a simple access-list 1 that permits any, and the internet is working. It's just the ISP router doesn't know how to get back to the internal networks. I have it fixed now. Thank you so much for your time to help. 🙂
