IOS/C6500: Difference between IOS Feature Sets
schuetzm
Frequent Visitor
Frequent Visitor
Dear all,
I'm going to install two C6509-E. Right now I'm trying to find out what are the differences between the feature sets:
- IP SERVICES SSH LAN ONLY
- IP SERVICES SSH
We need IP Services for EIGRP and QoS, furthermore i need to configure HSRP for some VLANs/IP-subnets.
Software Advisor says, that the features are common. So which feature set and image should i install??
Matthias
2 Accepted Solutions
Jon Marshall
Matthias
The LAN only does not have support for the flexwan and some of the WAN modules/cards. I can't find a list of them at the moment but if you don't have any you should be fine with either version.
Jon
Richard Burts
Matthias
The services that you mention are common in both of these feature sets. The difference is that the IP SERVICES SSH LAN ONLY does not provide WAN services (which makes its memory requirement less). If you need WAN services do not use this image. If all you need are LAN services then this image is fine.
Rick
Rick
Jon Marshall
Matthias
Jon
Richard Burts
Matthias
Rick
Rick
