IOS command - system mtu
anitachoi3
Does the command of "system mtu routing 1500" affect the trunk port only? if not, what routing port does it mean?
regards
Routed ports are layer-3 ports.  A routed port has an IP address associated with, it is not a switch port (layer-2).
Reza
Jon Marshall
regards
The command affects all packets routed by the switch, please see the command reference for full details -
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/command/reference/cli3.html#wp1948947
Jon
Grateful if the meaning of "routed port" would be advised as below sentence. Does it refer to trunk port?
"You can use the system mtu routing command to configure the MTU size on routed ports"
rdgs
Reza
